Wolfbox Install mistake? oops?
YVR_Phil
5:21 PM
Vancouver BC
Just did part one of the Wolfbox install. Bugger to get that wiring through the rubber grommets, etc. All good...however.... i forgot to hook up the red reversing light wire (or at least extend). Can you tell me 1) Is this actually needed given the camera is on all the time? or does it actually power the camera like other back up cams? Additionally, if it does have to be connected, is there a chance to get the power off the rear back up cam already installed (lower door)?
My understanding is that it only exists to project the "reverse lines" (for lack of better term) on the screen when you put it in reverse. I did not connect mine. Don't have an issue.
And yes, getting the cable through the door grommets was challenging.
The red wire is needed. It signals the mirror to switch to the rear camera view automatically when you shift into reverse. Without it, you'll have to manually press the button every time you back up.
Yes, you can tap into the power for your existing factory reverse light on the tailgate door. That's the standard way to do it. Just find the positive wire for that light.
With the red wire connected, when reverse gear is selected:
  • the display automatically changes to the rear camera if another camera/view was active
  • the rear camera view changes from panorama mode to full screen mode (zoom)
  • the reverse lines are activated
If the red wire is not connected, when reverse gear is selected:
  • nothing happens
@rob88 There is no need to press a button to activate the rear camera. Switching camera views is a horizontal swipe on the screen not a button press. The button turns the screen display on and off.
Where is the "...existing factory reverse light on the tailgate door." ?
Please stop posting AI answers.
I left that wire unattached purposefully. Didn’t want those lines. Ineos camera is better for backup IMO.
Really? I had the complete opposite experience. Wolfbox camera is far better quality, brighter screen, camera mounted inside and higher up, stays clean and much better viewing angle . I rarely use the Grenadier backup camera since installing the Wolfbox. If you hook up the red wire, you get 2 backup cameras, the Wolfbox can Zoom in and aim down, project lines, all optional on the menu. I had to add about a yard of wire and tapped into the reverse light wire.
No its not needed unless you have your mirror on front view and need it to switch to rear when you engage reverse. Or alternatively, you prefer your reverse image to be at a different angle to the normal rear view.
Mine is connected, but I find the reverse pointless as it's mounted too high on the vehicle to be useful.
The reverse viewing angle is completely adjustable. When in reverse, just use drag a finger on the screen to change the angle. It will remember the setting.
not sure why- but my camera is not remembering the setting...
It is adjustable but you don't get a decent angle from it being that high.
It’s driving me batty trying to find the correct colour wire for reverse lights.
Can you let me know which wire you used.? Thanks.
I spent hours (I’m a qualified Avionics Engineer…. go figure 😳) trying to wire the trailer hitch and coming across completely wrong & conflicting advice here & elsewhere. Even though I have access to the manuals the so called wiring diagrams don’t specify the colours only the connection pin outs.
