- Local time
- 4:07 PM
- Joined
- Jun 27, 2022
- Messages
- 57
This is a custom mount designed for installing a Wolfbox in the Ineos Grenadier.
When mounting the Wolfbox on the original Rear-view mirror, the cables have insufficient space and the overall setup appears bulky. To solve this issue, this simple and clean mount was designed.
Required Hardware
After installation, the mirror can no longer be angle-adjusted.
Material Recommendation
For best results, use a rigid and temperature-resistant material, such as:
Required Hardware
- 4 x M3x30 screws
- 4 x M2 x 16 screws
- 4 x M3 nuts
- Remove the original rear-view mirror.
- Remove the original screws from the Wolfbox, including the brackets for the rubber straps.
- Reinsert the four small caps.
- Attach the new mount using the longer M2 screws.
- Ensure the Wolfbox is correctly oriented on the new bracket before tightening.
- Position the printed mount in place of the mirror.
- Secure the mount using the specified screws and nuts (M3).
- Carbon fiber reinforced Nylon (PA12 CF)
- Carbon fiber Reinforced Polycarbonate (PC CF)
- (ASA/ABS) not tested
