Fifteen52 Wheels anyone using this brand?
C-Mack
2:40 PM
Utah, USA
Ran across Fifteen52 Wheels and they have a few nice styles which seem appropriate for the Grenadier. Curious if anyone has experience with the brand and if the wheels are legit in terms of quality and construction or is this another case of style over function?
Image below is for a 5 lug but they do offer the correct hub bore and bolt pattern for the Grenadier. Offset is 40mm which is 15mm more than stock but not overly aggressive as some other brands out there.
WHEEL DIAMETER 17
WHEEL WIDTH 8
BOLT PATTERN 6x130
OFFSET (mm) 40
HUB BORE (mm) 84.1
BACKSPACING (in) 6.08
WHEEL WEIGHT (lbs) 29.11
LOAD RATING (lbs) 3300
WHEEL DIAMETER 17
WHEEL WIDTH 8
BOLT PATTERN 6x130
OFFSET (mm) 40
HUB BORE (mm) 84.1
I have a different style in that color. I fit 35x11.5 on them with no lift and no rub. I really like them. No issues so far. The 40mm offset is just enough to push the wheels out a bit, but not too much.
