Wolfbox front camera alternative locations
GrenAF
4:02 PM
Long Beach
Has anyone mounted the Wolfbox front bumper camera in a location OTHER THAN the front grill? Been thinking if there’s a spot under the vehicle that can give the user a view of the tires that isn’t susceptible to being ripped off. Maybe above the cross member beneath the transmission pan? Any ideas on best path for wiring?
There are quite a few plugs in the floor pans that you could route the wiring through. Pull up the floor covering or there is also a few under the back seat.
I mounted mine below the bumper. I 3D printed a bracket..
More details please. Are you pleased with it? How’s the view from that location? Did you compare it to the grill location? I still need to install my front but I’m trying to avoid the usual place.
Reactions: CRH
Yes very pleased with it! I turned on the gridlines in the menu to have a point of reference when viewing,the closest line equivalent to 5ft. Sorry I cant compare to grill view, since I purposely avoided it. I wanted out of the way and least noticeable as possible.
Thank you. I may try this then. I’m horrible at printing stuff and think I can only do PLA.
I’ve also been thinking about alternative ways to use the front camera. One idea would be to use it as an underbody camera. Which perspective would make sense? Another option would be to mount it on the roof, providing a bird’s-eye view of the rear tow hitch. Could it be mounted on the ladder?
Right you are Tom. And don't forget to mount a cheap rock light in there as well so you can see what is going on, day and night.
How does it mount? Can you post some pics of the screws and the view from the mirror? Please let me know if you can print or at least upload the file. We would greatly appreciate it.
It mounts via the two existing screws on the bottom of the bumper, ill try to take some mirror views when im out and about…
The Wolfbox bumper camera has a quite narrow field of view. Is it possible to replace the camera module with something more wide angle? Where did you go through the firewall?
Are you happy with the bumper camera's field of view? I feel like it's way too narrow. I'd love to see the entire bumper from left to right in the panorama but I can't find a way to position the camera to make that happen.
Yes im pretty happy with it. I agree it would be nice to have a physical point of reference (bumper) in the view, but i somewhat overcame that by adding the gridlines, which helps. My main objective for the front cam was to make it the least noticeable as possible and in a location that was least likely to get damaged. I really like your design, I wish i was more skilled at 3D design, mine are not as refined as yours. You are very skilled!
