Windshield replaced - need advice
I agree, the design and application has a fault because they always seem to break in the same pattern, center bottom up to about halfway then they go towards the driver side (RT side drive) and back down, like a lower case n. Without seeing the installation at the OEM I cant say for certain but I don't like the placement of the spacers they use behind the glass relative to the height of the factory applied urethane. The spacer may be creating a point of stress as the urethane pulls the glass in as it cures. I don't use the spacers when replacing and have had zero returns with the same break pattern. Could just be luck but I've replace around 50 so far. Prior to owning my auto glass replacement business I was a supplier quality engineer in the automotive industry for 21 years with glass as my specialty commodity so this problem speaks to me and I would love to resolve this as much as the owners (even at the loss of business).
Awesome to have this inside industry knowledge on the glass, many thanks!
Fifty replacements in such a short space of time seems high to me given the fact that I guess most of these are “local” breakages.
Is this unusual to have this number at this stage in a new vehicle’s life?
I’m personally interested as I had similar issues with a new Defender that I owned before the Grenadier. (Each one lasted on average 5000 kms but they cracked after impact in 100% of cases)
Cheers
It would be great if @Tom D could get feedback on this view from Lynne to see if they acknowledge there is a problem and have taken action at the factory level to change process or supply to fix this.
I can ask the question.
Here's a thought do all the cracked screens have the ADAS bump around the mirror?
I finally had my windscreen replaced yesterday after a lengthy drama... In fact I had 2 windscreens, the 1st was installed by a regional installer specified by the insurance company against my advice and was a total stuff-up. Insurance then directed me to O'Brien AutoGlass Fyshwick in Canberra for it to be redone.
The first installer, apart from installing the glass crooked, the mirror crooked, scratching the glass, had also scratched the paintwork of the bottom edge of the window opening in several spots and even damaged the VIN sticker (also the creaking sound while driving at any speed was unbelievable). The tech at O'Brien Fyshwick did a great job with touch-up paint and then using a black weatherseal around the edge of the glass (similar to what has been discussed on this forum and Owl). He said it would help protect the edge of the glass from cracking, and had done this on Jeeps also. Looks good, almost better than OEM, no wind noise. The glass is non Ineos, branded as XYG.
This morning after -5C, no cracks!
Cheers
The OEM glass supplier for Grenadier windshields is Pilkington. An interesting topic is the ongoing class action lawsuit of the 2020-2022 Land Rover Defender windshields also made by guess who, Pilkington.
In fairness to both mentioned manufactures and a few others such as Jeep (most models), Mercedes (G-wagon) and Ford (Bronco). By having close to vertical windshields there is no way to avoid the physics of an impact and the transfer of energy to the glass surface. You wont likely have a rock "glance" off a windshield in these vehicles and, like Grenadiers, I change a high amount of the others too.
In fairness to both mentioned manufactures and a few others such as Jeep (most models), Mercedes (G-wagon) and Ford (Bronco). By having close to vertical windshields there is no way to avoid the physics of an impact and the transfer of energy to the glass surface. You wont likely have a rock "glance" of a windshield in these vehicles and, like Grenadiers, I change a high amount of the others too.
Thanks for this follow up, I came to the same conclusion and accepted the risk of the vertical nature of the screen. So far so good 😊🤞🏽
Just for reference and comparison... I still have my 1985 Land Rover County 110 with 330,000km on the original windscreen, and I have owned it for 25 years. It has many small chips, but no cracks, from extensive travel in Australia. I get regular rocks thrown at the glass from large trucks, that simply result in a chip.
My Grenadier received a small stone and chip within the first month of ownership, and the "typical" crack from the bottom left side edge (near the windscreen wiper) on a winter morning while parked in the driveway (no visible chip, and not related to the original stone chip). Over the next 15,000km it had received numerous chips and another crack.
If anything, the original Land Rover windscreen is more "vertical" than the Grenadier. I can only say, "they don't make em like they used too".
I have had me Grenadier since October 2024. I just went away for the weekend and the car was parked, when I returned there was a large crack on the passenger side of the window that is about 8" long from the vent to the middle of the window. No sign of impact, no chip. Not parked under anything. Its bizarre and with all the little problems I have had with the vehicle I am curious if this is something that others have encountered? (Other problems: This car is really "buggy", my tire sensors keep giving me a warning off and on but the tire pressures are perfect, all the door handles had to be replaced, it constantly drops calls on the bluetooth or callers can her me but I cannot hear them, the Apply Car Play works sometimes but not all times, etc)
I just received a crack today from a flicked up stone while driving in Canberra. It hit the windscreen middle to left about an inch from the bottom. Tiniest of chips, like a pin head (even smaller), but sure enough a crack has formed, going down to the edge of the screen and then up and across, about 8 inches or so in length.
Was just wondering what your process for getting it replaced was? Did you just go through your insurance, or did you contact 4x4 Garage or another Ineos dealer first to see if they could replace the windscreen using your insurance? How have you found the new non Ineos glass and the black weather seal around the edge. It looks like a pretty good install job. Any advice would be welcomed.
Cheers
Greg
Cheers
Greg
If you have insurance with windscreen coverage just get them to handle it. There are aftermarket XYG screens out there now and enough have been replaced over the last couple of years that national companies like Windscreens O’Brien should be able to easily handle it on behalf of your insurance company.
Cheers
Greg
I had windscreen coverage with Shannons. Initially they did not want to cover the replacement with OEM Ineos glass via a dealership, however now that there is the XYG non-OEM option through O'Brien, they arranged it had it sorted within 24hrs.
I would recommend O'Brien AutoGlass Fyshwick, since the older bloke there suggested and fitted the rubber trim seal surround, and atleast has seen and worked on a Grenadier.
ps. I had a stone hit the other day driving from Canberra on the XYG glass, and there was no chip damage!
The crack on my second windshield started from a chip, but it has been spreading primarily while parked just like you experienced.
Thanks mate, will see what the NRMA say. Sounds like O'Briens in Fyshwick is a good option, especially with the extra rubber seal.
I do the windshield installs exclusively for a large dealership in the southeast and it is possible the glass will move down if the tape is not sufficient while the urethane is curing behind the glass to the vehicle. What I have found to work best is utilizing the spacers on the removed glass (rubber piece approximately 5mm x 5mm x 20mm) between the bottom of the glass and the vehicle. By doing this if guarantees the gaping at the bottom is uniform all the way across. Adjusting the Y direction at the time of install is pretty simple and you are not working against gravity.
They may have attempted to reuse the original rain gutter but the $2300 covers a new one or they attempted to put the gutter on after the windshield install (very difficult). I put the seal on the glass with primer and urethane, allow that to cure as an assembly and install the set. This allows the hard part, seal over glass, to be perfect before the install. Only thing left is to peel the cover of the double sided tape and press it in. A small about of double sided tape residual may remain on the vehicle, I just make sure its free of dirt. That tape on the new gutter will stick to clean paint and clean tape residue.
The clip is actually the guide pins found on the bottom corners of the glass. Most, if not all, installers will remove those on the new glass as its almost impossible to align the pins to the guide holes when setting into wet urethane. The robot setting the glass at the factory can always go to the exact XYZ position so its not an issue at OEM level.
As for the rattle, when cutting the glass out of the vehicle the installer should do their best to cut between the clip and the double sided tape that holds it on. Likely (and it happens to me too), the installer broke the clip causing the pin portion (think of the pin like a chess pawn piece, bottom attached to glass, top is the tip of the alignment pin) to fall into the vehicle and creating a rattle sound. When I break the clip i make sure to recover all the pieces.
My windshield leaks. Was getting dripped on and could not figure out why until I followed the drops up to the top center of my windshield. A 2025, new, and another, I assume, warranty issue. Why do these windshields not have a seal on them as do most others? Not happy with this at all! Any simple fixes?
