What fits in teardrop opening in headliner?
cdsvt
1:50 PM
Vermont, USA
I have a factory dog barrier installed in the rear set, what fits the front set?
Ah, thanks. Are those barriers available in the US?
Have a look on the configurator, If the 2 seat is not available in the US then I have a feeling you're out of luck, there are fixing points for the 2 seat that the wagons don't have also.
Thank you. Too bad, as this would be handy offroad. Removing the second row seats and putting a flat platform in place, with a barrier behind the front seats would be the same configuration I run in my land cruiser 80 series. It protects the passengers from projectiles.
What is that for?
Just a grab handle to make entering the vehicle a bit easier on folks. There’s a link To the printable file for the plug in the resource section. I did to mine as well and even though I rarely have tear-seat passengers it was worth the effort.
If I end up using this offroad, I may see if the rear barrier fits the front holes and weld up a frame to attach the bottom portion to. For now the 80 series has pride of place for hard wheeling trips.
