I wasn't witness to the unbogging of the tractor, but it came out with 4 MaxTracks and a lot of digging! I was extremely surprised, I thought it was going to be left until summer when it dries out!!
Glad to hear that.
At least with a front loader you can lift the front end up to put maxtraks under and in most circumstances can roll the bucket to push yourself out or pull yourself forward when stuck.
Glad to hear that.
Yes, that was done initially, but when the surface was broken it filled with water. MaxTrax were easily positioned with the front wheels when the bucket was pushed down. Back ones ....well....let's just say the shovel was well used.
Changed the oil again.
Got Liberty back today. After having gearbox replaced, replace rear right axle shaft seal, new transfer box cables, heat shielding around gearbox. LRA auxiliary fuel tank fitted. OEM heavy duty black marked springs all round. Airbagman air bags in rear springs. Note the the air nozzles adjacent to the rear recovery points. Reroute exhaust to facilitate fitting of auxiliary tank. Note only one exhaust tip now. Wheel alignment all round.
Drives great. Definitely sits higher although mine seemed low before compared to my mates Fieldmaster spec. I bit stiffer ride but still super comfortable, this stiffness will change once the springs are bedded in and vehicle kitted out for travel. A nice burble to the exhaust sound on idle and a louder hum at motorway speeds but not too intrusive.
Compass Automotive have been great throughout the whole process and always giving progress updates. I can’t recommend them highly enough. A great outfit and Tom super helpful.
Got Liberty back today. After having gearbox replaced, replace rear left axle shaft seal, new transfer box cables, heat shielding around gearbox. LRA auxiliary fuel tank fitted. OEM heavy duty black marked springs all round. Airbagman air bags in rear springs. Note the the air nozzles adjacent to the rear recovery points. Reroute exhaust to facilitate fitting of auxiliary tank. Note only one exhaust tip now. Wheel alignment all round.
View attachment 7908025View attachment 7908026View attachment 7908027View attachment 7908028View attachment 7908029
What you've had fitted gives you a theoretical 4000kg GVM in Australia, not sure what the legalities are in the UK.
Definitely needed in most Grenadiers IMO, I'm running at 3200kgs with half a tank and me in it.
LR tank is a must for sure.
All set for the next adventure!
What caused the need for new box and transfer case?
🤫 on the weight. 😂 both myself and my wife are small , we pack lightly , hardly eat anything , don’t take any spare clothes ,tools or vehicle spares and don’t drink much water 👍🏼
Front prop CV joint C clip failed last year and very small cracks in aluminium casting of gearbox where plastic pan fixing screw fit. This caused a very slow weep which wasn’t recognised at the time of the initial repairs.
Getting ready for more adventures although the next one is without the Grenadier as we weren’t sure on timings of upgrades. Next year now before a new Grenadier adventure
Some great updates to a pioneering Grenadier!
