Lots of dirt at DVNP and now in Vegas
To many people to thank for help and pioneering the mod. Today I added my Midland GMRS radio with the antenna attached to the lashing bar and cable run through the Aux point. I ran cable down the inside of B pillar. Currently the radio is in the center console. I think I'm going to move it to behind the glove box but that will be a later date when I have to connect to the aux cables.
Revision 2.0
Here I made a second unit...first was only using two screw mounts. Here I am using 4 screws. I used 1/4 plastic tubing as a spacer to keep the place from scratching the factory plate. I bought a 35mm bolt for the long screw replacment, but I think it is still too short ( it wont tighten).
The mount and ball I am using is from Tackform (I had this on my Bronco). It's an anti-vibration unit.
I started with a scrap piece of aluminum I bought from my scrap recycling yard.
Cut it down and drilled holes, and tapped one hole. Painted with Bed Liner paint (great stuff!)
1/4 polyflow tubing spacers.
Small standoff to protect the OEM plate and graphics.
Here I preserved the "Seat Heating" description.
Chapeau. Much less sophisticated, i use a cheap silicone piece (from Ebay). Smartphone is stowed away, is connected and being charged, does not rattle. Phone, navigation, music etc. I operate through the central display. Almost zero Android issues.
I have discovered that I can start the car, put it in drive and move the car with my drivers side door open. I thought this cannot be done. I must be the special one. Next time, I will try having the bonnet open to see if I can start the car.
Not so special ;-) : Reversing with trailer
