I view it as a temporary fix, when I do not have any other options. Sometimes help can be a very far away in remote parts of Australia.
"Mulga stakes"* in Australia can cause multiple punctures, therefore my 2 spare tyres may not be enough.
*Parts of Mulga trees can become like stakes that easily puncture tyres when driving.
Great! So even the trees down there try to kill you too!?😂
Don't know about US or Aus trye law, but whilst repairing the sidewall for offroad situation will get you out of immediate trouble it is illegal to repair the sidewall of a tyre on the public highway in the UK. Tyre depots/shops are not permitted to repair a sidewall.
Definitely not a permanent fix and I wouldn't run it at highway speeds. I don't know if it is "illegal" to repair a sidewall in the states but no shop will do it.
I think I look at tire repairs different than some. I would rather keep fixing the same tire on a trail rather than install the spare. I want to keep that spare as safe as possible until it is absolutely no other option.
Not a good day for Baron Bigglesworth. I took it in this morning for the 36k mile service. I also still had the Jan 1 service error, and couldn’t clear it because the button on the left turn stalk stopped working. Oh, and the passenger side windshield spray nozzle wasn’t working. Half way from Madison to the dealer, on cruise control at 65mph, suddenly I hear a rattle from the back. I thought maybe my WeBoost antenna mount was coming off, but then the check engine light came on, I get a “powertrain error” code, and the engine goes into limp mode. Like 1/10th response on the accelerator, drifting along at about 30mph. Pull off the side of the highway, turn it off, then turn it back on. No check engine light and it seems to be running fine. Get to the dealer, and while they’re doing the inspection, they find the boot on the front drive shaft has started to tear (no lift, stock tires). They’ve had to reprogram everything (they say the power loss was software), are replacing the whole front drive shaft, and have to replace the left turn stalk. I don’t like to think about what this would all look like without a warranty - but that deadline is coming up quickly.
I did something about the poor sound in my Grenadier.
I have the two-seater which only has two speakers in the driver and passenger doors. I replace those with Hertz CK165 woofer and separate tweeter which I mounted on the A Pillar.
Well, for a small investment I achieved a massive improvement in sound quality. Bass is improved and the high end is much, much better than the OEM speakers.
I also added 5" speakers in the rear doors, and these are easy to wire up as the Ineos wiring harness has the wires up to the B Pillar and all I needed to do was run some wires into the rear doors. I'm in the process of sourcing proper terminals to complete the installation. When next at a dealer, I'll ask them to enable the fader for the rear speakers, but they work without this. They don't make as much of a difference as the fronts but will improve the sound marginally for little cost.
Some trimming to enlarge the front and rear apertures is required but with a Dremel, a relatively easy task.
Happy days.
Happy days.
Where did you mount the crossovers?
I sat in my vehicle today holding that same tweeter from the CK165 kit debating if I want to put it in the A pillar cover as you did, or in the door card trim near the inside handle as others have done. I see benefits both ways. In the door means the crossover and additional wiring could (probably) stay in the door. In the A pillar would lift the sound stage higher and give a better result but it's a slightly more complicated installation.
The higher the tweeter the better the high-end sound stage (as you said) I just made the crossovers disappear into whatever space I could find - more difficult on the driver's side. For the moment, they are not mounted due to access issues, and I'll see how that goes. Seeing as you are going into the door it may be easier to mount the crossover there, but you might have to remove the inside card as well.
CONSOLE ERROR
I had the New Year servicing error fixed. It took about 10-15 minutes.
ENGINE COVER
They replaced the engine cover - again (diesel). That is cover number 3.
BROKEN TAILSHAFTS (AU)
When I asked the Service Manager, he said about 85% of cars with broken shafts had big lifts and big tyres. They are being told no warranty response, because it was caused by their changes.
The others were being considered on a case-by-case basis by INEOS ANZ.
He knows of one case where the owner installed a 2.5 inch lift and big tyres on a QM, and the shaft broke within a few hundred metres after leaving the shop.
Another owner put on large tyres and they severely damaged the mud guard, the brakes lines and the ABS sensors. Common on guys! Apparently, he liked large tyres!
HEASMANS SYDNEY
He spoke very highly of Heasmans, who did my suspension work. Not cheap, but very good quality.
I second that.
I finished the door table install, mounted the DVA roof rails and mounted the Yakima Double Haul fly rod vault. Then went and played on the gun range in the back forty
View attachment 7922597View attachment 7922598View attachment 7922599View attachment 7922601
240g .460 - ooof. what's the recoil like on that?
CONSOLE ERROR
ENGINE COVER
HEASMANS SYDNEY
I second that.
Hi Doc, why the 3rd cover? Presume changed first one due to recall but what was wrong with the 2nd one?
