WE Boost - Cell service signal boosters - Drive Reach Overland
Stu_Barnes
Fixer & General Dogsbody
6:00 PM
Los Angeles
We boost have provided us with a 5% discount on their products use code INEOS5 when checking out.
  • This is it. Your game-changer on the trail. Drive Reach Overland maximizes available cell signal so you can call, text, navigate, even post photos and stream data in more places than ever. It’s the perfect mod for your mighty rig.
  • Features an adjustable outside antenna mount that easily folds down to clear roof gear and trail hazards. The antenna’s versatile bracket attaches to your rig using a T-slot, pole, or fixed mount.
  • Supports multiple devices on every U.S. cellular network, so your whole crew gets a powerful boost for extended connectivity and peace of mind.
  • Includes everything you need for easy installation (optional hardwire kit is available).
  • Install it once and you’re good to go – no subscriptions or maintenance.
  • Backed by a 30-day, money-back guarantee and 2-year warranty from the world leader in cell signal boosters.*
*their words not mine....
I just bought a DRIVE REACH OVERLAND and forgot the put in the code.
Tried another cart and it works to get he discount. Now I need to chase up their customer services to get my 5% off.....
It's been one of those days.
Edit.
Just had a reply from weboost and they applied the discount code for me.
Ok. Install completed. And it’s looking good. Next the how to guide after I shrink wrap and tidy up the antenna connection.
Stu, have you put the booster to the test yet? Curious if it works
It definitely works... It won't work miracles, but will increase reception in areas
It's
Is it a meaningful increase or is it mostly marginal?/
How far apart should I keep this antenna from my gmrs antenna?
Absolutely meaningful, I haven't had a vehicle in the past 6ish years that hasn't had one on it.
Ideally any two antennas on the exterior should be at least 2-3ft apart
Do you have to plug your phone into a cord or does it just boost the signal wirelessly for everyone in the Ineos? I have a wireless signal booster at home, does it work like that?
Depending on which interior antenna you have your range of "boosting" is between ~1' to 10' from the antenna
