Warning about stock KO2 R18 tires
4x4Brick #1561
10:56 AM
Short story – maybe consider R17s for ease of replacement over R18s.
Long story - I knew when choosing between the two stock sizes of tires when ordering the Grenny that the KO2 R17 and R18’s were the same height. I opted for the R18’s because bigger is better right? I’ve been very happy with the tire as quiet enough for city driving and aggressive enough off road. However just came back from a week-long trip through Colorado and Wyoming. Day 1 of 9 on the trail and I was driving on Engineer Pass outside of Silverton Colorado and made an uphill climb on a more than 90-degree switchback over some rocks. Greeny sild a bit on a rock and BOOM – punctured side wall and bent rim. Then it started to snow but that’s another story. Switched out to the full size spare. Yay. But now I’m in fairly remote county with just a series of small towns trying to find a replacement tire for a spare. Didn’t want to risk not having a spare for the next eight days and the Greeny lugs don’t match up with the Tacoma and Colorado trucks that I was with. Called and called every tire shop, 4x4 outfitter we could find along our route and they had the KO2 (or really the KO3’s since they are current I was told) but in R17, not R18s. Even called Ineos Roadside and the Ineos Dealer in Denver. If I wanted to back up a day the dealership had them in stock. We did NOT want to back up a day – Tetons or Bust! And this is Colorado and Wyoming where almost every vehicle you pass is a truck or jeep. Finally found a R18 (not a KO but a similar enough to make a useful full size spare) at a Big O Tire store in Frisco (the blue collar town that supports Breckinridge Colorado). Big O bent the rim back in shape (yay steelys!), new and mounted tire for $337 and I was back on the road and the Mrs was happy to hear I had a spare again on the trail. If I ever find myself need 4 new tires, I seriously might consider switching to the R17s for availability.
Oh – ABSOLUTELY take off your spare tire once before hitting the trail. The torx bolts from the factory holding the plastic spare box on are super tight. If a nice Jeeper with a cordless impact hadn’t stopped by I’d likely have had to mangle the plastic to get them off – In the SNOW!
I don’t know why r18 steelies was even offered and why would anyone pay extra?
I’m stuck with the r18 rim because the vehicle had it
You don't know what you're missing!
Oh , you do now ;<)
No Aussie would put 18s and steelies in the same shopping trolley. It'd be a bigger faux pas than ordering Fosters...anywhere in the world.
Ouch, that's a rough start to a trip. Thanks for the real-world advice.
The R18 tire shortage in remote areas is a major issue. Your story is a perfect example of why switching to R17s for easier replacements is a smart move for the future.
And that's a great tip about testing the spare tire removal before you need it. Those factory bolts are no joke. Glad a fellow traveler was there to help.
I've found that before. 17" being much easier to find as they are often fitted standard to pickups here, as will as the Wrangler of course.
LOL. Bigger is better right? No! Same tire size in diameter but wheel size being 17” or 18”? Performance wise off-road, the smaller wheel diameter gives a much taller sidewall which will give more flexibility at air downed pressures. This increases there bite and grab on uneven surfaces and also protects the rim better.
I B was looking at two Trialmasters one had 17” Steelers the other 18”. If much prefer the 17” wheels but everything else on the version with 18” wheels suited me better and I bought that one.
As with anything Grenadier, nothing is cheap as to Mid’s but changing wheels is by far the cheapest mid I can see so far.
I’ll run the KO2’s to ground and then change out to the smaller 17” wheels.
Just as an example. I run 37” tires on 15” wheels on my Jeep YJ rock crawler with beadlocks an when sired down to about 10 lbs psi they stick to everything like Velcro
Manufacturers and the aftermarket have brainwashed consumers into thinking low profile tires are the ultimate fitment. I see one-ton pickups driving around on 20” wheels, 30-series tires and massive outboard offsets - obviously ridiculous, on or off the road.
When Jackie Stewart taught at his own road-oriented driving school, he would start students out in a 1970’s station wagon with 70-series tires. They’d be shocked and ask why they weren’t starting out in something more sporty. His opinion was that low-profile tires had no place on public roads - their handling and performance characteristics were intended for smooth race tracks, not public roads.
Tall (or taller) sidewalls have an important function, especially on public roads and rough terrain. They make for predictable transitions in grip and provide the flexibility(with lowered pressures) to avoid damage that might otherwise occur to lower-profile tires.
This same problem exists for any "non standard" tire size. The rim size doesn't matter, and it certainly isn't unique to Grenadier. You're fortunate that you could have gotten a tire just a day away from the dealer. Or, you could have ordered one from tire rack or whoever and had it shipped ahead of you to the next destination. Seems like much ado about nothing tbh.
