Australasia Tyre/tire pressure alerts
TheDocAUS
6:25 AM
Eromanga
Allow categories of tyre/tire pressures alerts based on usage, user adjustable like:
  • Sand
  • Gravel/Offroad
  • Rock crawling
  • Mud
  • Towing
  • On road
The user can then swap between categories, as needed.
The alerts will trigger on the high and low limits set for each category. Or at least give the user 3 categories which they can name. For me that would be On road, Towing and Sand.
Plus be able to clear alerts, like the tyre pressure warnings.
Adding my few cents. Entering off-road mode should disable the low pressure warning. I generally always air down and enter off-road mode when I go off-road and it will be nice to suppress those warnings without having to reset the temps target pressure
This oughta be the simple work around that is entirely feasible.. just do it Ineos.
How about just giving us a broader range. With 35” tires, If I set the pressure cold then I get an over pressure warning on the freeway when they warm up. If I set them when they are warm then I get a low pressure warning at startup.
