Build Thread Trinity Build
angstorms
4:44 PM
Durango, CO, USA
Decided to name the truck Trinity after the Trinity Peaks in Grenadier Mountain Range in the San Juan Mountains in Southwest Colorado where it be spending most of it time.
Finally had back in Durango so had some time wrench on the truck,
Installed
- Leitner Designs ACS Roof Platform 3/4 Rack
- Leitner Design Maxtrax Mounts
- Leitner Design Front Bumper Light Bar
- Baja Designs LP6
- Baja Designs Squadron R SAE Floods
- Owl Outdoors/Owl Vans (https://owloutdoor.com/) Accessory Mounting Rail
- Owl Outdoors/Owl Vans (https://owloutdoor.com/) Rear Door Handle
- 2 Bulletpoint 20 m Bulletpoint mounting balls
- Bulletpoint Mag Safe Wireless Charger
- Storage Organizer Box
Installing today
- Letter Scene Light brackets
- Baja Designs S2 Sport Lights Pods
- Quick Release for Fire Extinguisher & 5 Lbs Fire Extinguisher
Looking good
Trying to test fit the Front Runner Nato Can holder, I can get great connection down at the airline track, now have to work on addressing the gap at drip rail, it was about 1/2 inch shorter and the base was drilled out to 3/8 of Inch , this would be great out of box solution out of the box.
Installed
- Baja Designs LP6
- Owl Designs Accessory Mounting Rail
- Owl Designs Rear Door Handle
Installing today
Who makes the rear door handle and the phone holder, please??
View attachment 7858704View attachment 7858705View attachment 7858706
It's hard to tell from the angle but those top clamp gaps may actually be useful to be able to install a protective barrier between the Frontrunner mount and the painted drip rail. Perhaps a strip of HDPE or similar.
good job.
where did you buy these containers?
Hi All,
I thought this may be of interest to some. Here is my solution to roof rack/camping lights that require no drilling to mount. I think they look quite good. I hope this inspires others.
good job.
Picked it up on amazon, right now only right side box fits my truck, I have Left side but it was for truck with inverter installed. Look up Ineos Grenadier in search on AWS, you find few items "Car Trunk Storage Panel Compatible with Ineos Grenadier 2020-2024Retrofit of The Storage Bracket on The Side of The Trunk,Trunk Side Fence Storage Tray Bracket Accessories (Right)"
Hi angstorms, That install looks especially nice on the rack. Nice find.
DaBull
Leitner has light mounts
Hi All,
That is cool but will not work on Leitner rack, Note they have small bracket to support lights.
This mount area for light bracket
Example with the Leitner bracket installed and Baja Design LED light bracket installed.
GRMS Radio Antena Installed, pulled. wire into the truck, that was not that bad came through that same hole as the brake lights, now working on the GRMS radio install Wouxun KG-100G Plus, see where best place the radio panel which can be sperated from the radio.
I think I am using the same GMRS Antenna (but with a more ‘direct’ cable entry under the smaller rear door).
Magic L-track bolts used to connect the antenna plate and Front Runner Nato Can Holder.
Picked up on Amazon "8 Pcs L-Track Double Lug Threaded Stud Nut Fitting Tie Down| Used with L Track Rail for Truck Bed,Trailer Cargo Control,Pickup,RV,ATV,Bearing 6000 LBS Heavy Duty Steel"
