Tremec gearbox cannot be switched
The pin was discussed a while ago, here is replacement https://www.mcmaster.com/91610A411/. Note they even have Solidwork cad file for the pin.
Shaft TypeSlotted
Material18-8 Stainless Steel
Diameter3 mm
Length24 mm
For Hole Diameter3 mm to 3.1 mm
Wall Thickness0.6 mm
Double Shear Breaking StrengthNot Rated
Minimum HardnessNot Rated
Specifications MetDIN 1481, ISO 8752
End ShapeChamfer
End TypePlain
Fastener Head TypePlain
PassivationPassivated
PerformanceCorrosion Resistant
Pin TypeSpring
System of MeasurementMetric
Country of OriginChina
DFARS ComplianceNot Specialty Metals Compliant
Export Control Classification Number (ECCN)EAR99
REACH ComplianceREACH (EC 1907/2006) (06/27/2024, 241 SVHC) Compliant
RoHS ComplianceRoHS 3 (2015/863/EU) Compliant
Schedule B Number731829.0000
USMCA QualifyingNo
My fabric cable tie is holding strong but it would be classy to swap the pins. One of these days...
Since it worked OK for 20k km, and you can get diff lock OK, I'm wondering if it isn't a cable connection issue 🤔
I have 50,000 k on mine now and still on occasion it won’t go in. However rolling back with steering input always fixes it.
8
I had exactly the same problem this morning. It was -4 overnight and I needed to move a horsebox through a muddy paddock. No issue with diff lock but it won't, no matter what I did ( roll, turn) go into low ratio. However after 10 minutes of engine running and the transfer temperature up to + 6 it went in with no trouble
8
Interesting… Damp inside the Bowden cable, freezing and sticking the inner to the outer???
I can’t see how the oil temp could make much difference apart from a little stiffness perhaps.
The temperature would get rid of any ice though
Lost my low ratio altogether this morning. No issues with diff lock. Spoke to Lloyds Allroad, at Carlisle, and then called in this afternoon. They sorted it in 10 minutes, it was the Bowden cable adjuster under the inside transfer leveler, had come adrift. Their service is excellent. I'm very fortunate in having a very good dealer that is very close to my location.
J'essaie d'acquérir des connaissances de votre part.
Mon Grenadier à 33 000 km (environ 20 000 miles). Je l'ai acheté en juin 2023. Le transfert a été modifié sous garantie en juillet 2023. (Il ya eu un appel)
Ces derniers mois, je ne peux passer les vitesses inférieures que lorsque le moteur est chaud. Lorsque le moteur est froid, il n'y a aucun moyen de passer les vitesses inférieures.
Le blocage du différentiel central ne pose aucun problème.
Avec le moteur chaud, je peux facilement passer les vitesses basses et élevées.
La voiture est chez le concessionnaire depuis hier et je suis sûr qu'ils trouveront le problème, mais je veux connaître vos commentaires.
Merci
Bonjour,
J'ai eu des difficultés à passer en vitesses courtes, mais surtout à revenir en vitesses longues.
Cela a été solutionné par le réglage des câbles de commande.
______________________________
Traduction Google :
Hello,
I had difficulty shifting into short gears, but especially returning to long gears.
This was solved by adjusting the control cables.
I had the same issue with the pin falling out while in the Tassili n'Ajjer in Algeria. My friends pitched in, stripped the transfer case lever, found the pin and reinstalled it. (during a sandstorm). Tricky bit was getting the spring back in the right position. Its a weak point in otherwise very strong and capable vehicle.
I’m now a victim on the pin falling out too. Right as we were starting our ride this morning, I noticed it while trying to shift into 4H-locked. Lucky enough I had heard about the issue and knew to look for the pin and found it. But we had really bad cell service and I couldn’t pull up the forum to get all the details. I found the pin, but couldn’t get it back in so had to take the bypasses on anything too serious (I explained this to my wife as “we now have a 6000lb AWD suburu, lol). I was thankful it was stuck in 4H-unlocked, so I could drive 50 miles home.
I’m headed to the dealer on Thursday for an oil change and software update and will have them fix it then, and will definitely be wrapping the bottom of the collar in black electrical tape to keep it in moving forward if there is not a “fix” to stop it from coming out again.
To prevent the pin from falling out of the shift lever, I cut a strip of about 1 cm of bicycle inner tube and wrapped it around the lever. It feels good, isn't as sharp as a cable tie, and doesn't stick like electrical tape and you can easily take it off if necessary.
I bought the new tube for €1.99. from one of these cheap dealers and also use this tube to make things like rubber bands to hold lashing straps or tools together.
Thanks, added to the links in Resources.
