Travel Sickness
rob88
9:52 AM
United States
Is travel sickness a common feature of driving in a Grenadier? I took one for a test drive over varying terrain including a bumpy, windy road and my poor wife developed travel sickness. Of the four other cars we have taken over the same route, only the Grenadier was accompanied by this side effect.
When I was a child, whenever I travelled in our family car I got travel sickness. Dad fixed this by installing a metal impregnated rubber strap that touched the road intermittently. The logic behind this was that static electricity build-up which was inducing the sickness was being discharged to the road by the intermittent touching. I know that jet airliners have probes that point backwards and from the trailing points, static electricity is discharged. This is a real phenomenon and the treatment simple and effective.
Can I have a feeling from other Grenadier drivers about this issue. Is it real and what strategies have you taken to prevent it?
It’s likely the B-pillar location. It’s pretty far forward relative to most other cars. Was she sitting very far back or low? Lift the seat a little. That may help. I noticed the pillar location while test driving, making a right turn at an angle and leaning forward a bit to see the cars coming. Not an issue for me at all, but could be for some🤷
If you get a tens unit, and put the pads on your temples at level 10, it'll balance your soul's magnetic field with the smart alternator that's causing this by not charging the battery to full. What you're feeling is your soul tearing away from your inner ear due to a low battery charge.
Not caused by static but could be the motion. If you feel as though it is static the person will only need to touch something metal in the vehicle like the body then they will be discharged to the vehicle just like you are supposed to do when you fill our tank with fuel. Touch metal and its solved. FYI airplanes have that static dong because they are avoiding it turning static into RF and interfering with transmission.
