Transmission Error
ECrider
12:06 PM
On most ignition starts now I get the amber triangle warning in bottom right of the driver's dash and the amber warning in the big screen "Transmission Error". It disappears about 2secs after engine turn over.
Been happening for a couple of months now.
Just wondering whether anyone else has experienced same and if so what it was/wasn't.
Last time agent checked they couldn't find any error codes.
I have this (and some others), but only occasionally. When codes were read there were lots of CAN communication errors.
Try keeping ignition on as long as all warning light go out before starting. This should be enough for all ECU's and CAN network being awake.
Thanks. I always allow the ignition to cycle and lights to extinguish. Unfortunately no difference for me with this particular error.
I had a red transmission error warning whilst in Morocco. I had a Tuareg guy in the passenger seat who wouldn’t wear a seat belt so after a while because of all the warnings we fastened the seat belt behind him. When he got out I forgot the seat belt was still fastened without an occupant in the seat. This caused a red transmission error. Checked the handbook and it says stop driving immediately and call your service agent. A bit worrying at the time in the Sahara. Turned the engine off went for a couple of beers for an hour, came back undid seat belt and all sorted 👌🏼
I have had similar since day one. After turning key to accessory the Christmas lights cycle on and off but warning triangle stays on and the transmission warning comes up, wait a couple of seconds and both go out and then I start the car and it stays clear.
Sorry no answers but have had exactly the same issue almost since day 1, for at least 12 months now. Local mechanic has not found a fix.
"I always allow the ignition to cycle and lights to extinguish. Unfortunately no difference for me with this particular error"
I have always done this also.
It seems to be happening most of the time to me now. To start with I thought it only happened if I started the engine with the driver's door open or without buckling the seatbelt, but it now seems to be about 8 out of 10 starts even if the door is shut and the seatbelt fastened.
I've also found that if I stop the car and switch the engine off, but leave the key in the ignition and remain in the car (for example to take a break from driving) for long enough for the car to "go to sleep", when I restart and drive off, then I get an "Engine Control Error" message which persists until the next "sleep".
Has anyone plugged in an OBD tool?
Hey Guys. This happens to me all the time. The only way to get rid of this is to lock your car whenever you get out of it. The ECU needs 35 minutes to totally shut down. This is what the dealer told me and it actually works. I noticed the battery was also sometimes a little low and it was because of the same reason. Lock the car and wait a few minutes, then it try again. Not a great system, especially when overlanding, as you never want to lock your car all the time. I hope they can find someway to fix this with a software update.
Update. Had the latest software update a few weeks ago, as well as the starter motor and alternator cable adjusted as per recall. Have not seen the light since. Thought you guys may be interested to hear.
Tks. Out of interest, what is the software version it has now? Last 4 digits.
... what is the software version it has now? Last 4 digits.
That doesn't help. We can only access the software version of the head unit (i.e., the display). Everything else is located in the various control units in the vehicle. Each of these has its own software version.
Well I hope everyone’s gets sorted. Was the only thing left that was bugging me.
