Transfer Box Lever
Hicarus
1:04 PM
LICHFIELD UK
There is a nut on the side to put it into true neutral its in the manual. Not sure if you can leave the stick in the middle Ala Land Rover 110 (danger of it slipping back in) or the neutral screw holds in in neutral for flat towing.View attachment 7807460
Yup, that's the bit I was thinking about - manual neutral selection, not the emergency tow-it-home nut underneath.
Looking at the hi/lo shift selector rod there are only the two detentes on the rod. If there were three then there'd be a central neutral spot just like the JLR boxes of old.
1:04 PM
Its not a proprietary box IG designed it and Tremec make it.
1:04 PM
I thought the "tow it home nut underneath" was a standard ZF bit. I'd be curious to know if it's still there?
Hicarus
1:04 PM
LICHFIELD UK
Yup, according to the book it's still there in one form or another.
2:04 PM
Why would you be changing it "In the heat of battle"?
The vehicle is always in 4wd high range, you are never in 2WD
From there you have only a few choices that will be made when the vehicle is stopped or at slow speed.
  • Stay in high range but lock the transfer case
    • Only done on a loose surface when you will be travelling reasonably fast
    • Off road mode probably selected first
  • Change to low range centre transfer case unlocked
    • Probably on a hard surface when towing a heavy load or pulling a boat up a ramp
  • Low range centre diff locked
    • Only done on a loose surface usually at slow speed
    • Tyres are probably aired down
    • Rear locker often also engaged at this time
    • Front locker may be engaged.
  • Selection of front or rear locker more likely to be done "in the heat of battle"
You'll be the one to explain this to my wife. (y)
10:04 PM
When I've had too many, and ill be damned if I'm leaving the Grenadier in the pub carpark overnight
I know a lot of cases where the husband/boyfriend/life partner has too many and gives the keys to their wife/girlfriend/etc etc only to see her get done for driving over the limit.
My wife and I walked up to an RBT caravan at the end of our street after we had both had 3 glasses of wine and they tested us just for fun
She was 0.04 and 15 minutes later at 0.06 with no more drinks
I was 0.02 and then 0.03
She weighs around 40-45kgs
I am 3 times that
So it is unfair for me to make her the designated driver as in reality she could only have 1 drink, maybe 2
So I only drink water or 1-2 glasses of wine
If we know we both want to drink we get a lift from a friend or a taxi
10:04 PM
I have always been a little crazy.
On the other hand, I may drive her SLK as well. :)
My wife gets annoyed if I drive her car as I adjust the mirrors, seat height, backrest angle, position and then the radio station and volume.
I can't even get into her car with the seat in the position she has it in
She is around 149cm or 4'11"
Spjnr
1:04 PM
Essex
I am 3 times that
My wife doesn't really drink! so no worries there then, unless they up the alcohol content of lemonade!
10:04 PM
I am still confused as to why anyone is planning on letting their wife drive the Grenadier.
What's good for the gander is good for the goose
If the gander trips and breaks his arms when remote, he turns into a goose.
Speaking to people leads me to believe that not every goose feels comfortable flying in a helicopter.
Logic thus dictates the other half should know how to drive a shared 4x4🙂
Hannes01
2:04 PM
we share the driving.
i drive to the restaurant / pup where i have a drink.
she is going home.
fair division
10:04 PM
Pretty sure I already posted this here about a year ago but here we go again
A few years ago a couple of retiree grey nomads were driving across the Nullabor in a motor home and the man pulled over to take a closer look at nature for 3 minutes.
Unfortunately he got caught up in the seat belt and fell out breaking his hip.
His wife didn't know how to drive so he somehow managed to get back in and drive until he had phone reception.
A plane landed on the road to airlift him out and a cop drove the motorhome, and wife, into town.
