Tow Bars
Keith baker
12:40 PM
Tring
Does anyone know of a tow bar kit for the Ineos rather than the very expensive OE one?
DenisM
9:40 PM
There isn't one as yet. And from all accounts the original Ineos towbar requires fitting during production... no news as to whether that may change...
Eric
12:40 PM
Scotland
Go with the Ineos fitted at factory since it will be warranted and software programmed for tow bar, and fitted into the canbus if needed, and there is no alternative
Dermot
12:40 PM
West Sussex
Hi Keith, I popped into one of our independent tow bar fitting companies with the same question. He advised me that it would take around 6 months before after market tow bars appear on the market. Obviously he doesn’t have any inside knowledge but years of experience dealing with new cars and the aftermarket equipment. I just hope he is correct as I would like one fitted to my fieldmaster. Please post online if you are able to source one.
Dermot
Keith baker
12:40 PM
Tring
Thanks Denis. It is on the accessories price list which usually means it can be dealer fitted? It looks simple enough; the rear bumper flap is removed and then it looks like 4 bolts. Don’t know about the electrics though. Keith
12:40 PM
Lanark, Scotland
Arkaig
12:40 PM
PH34 4EL, Scotland
@Keith baker There's no mention of a towball and electrics on any Accessories Price List - it has always been a factory-fit option requiring to be specified at time of order.
Eric
12:40 PM
Scotland
Factory fit only, not dealer, suspect this is more to do with the electrics not tow ball.
Trialmaster
12:40 PM
North of Watford!
Unfortunately, factory fit only at the moment. I made a huge mistake by not ordering one.
The hardware is simple, it's the electrical hook up which is the problem. I m sure in time someone will do it, but I am waiting for a Grenadier approved agent fitment.
anand
7:40 AM
Maryland
This is most likely accurate... The tow ball assembly simply bolts on.
As @Trialmaster stated, I'm 100% positive the electrics will be made available from some company (or at least instructions on how to wire it yourself) in the fairly near future (<12 months). At least here in the US, when the electrics are available from some other manufacturer, they'll rarely (if ever) be 100% "approved" by the OEM.
Realistically, doing the wiring yourself would be quite simple with a few relays and piggyback off of the factory taillight wiring, but I understand the intimidation factor in doing that and the simplicity of having a pre-made solution available
joejet
12:40 PM
Far far away
12:40 PM
Just fit one of these ??
I don't think there's one available that will bolt up to more than just the two M16 towball fixings. I think I would want pick up on at least two of the M12 fixings, if not ideally all four.
12:40 PM
Lanark, Scotland
If you only have a 2 bolt fixing then these points will be designed to take the load.
Fitting an adjustable ball will not change the load on the bracket and the adjustable plate will be strong enough in itself.
You could weld a plate on, drill a couple of holes and then use 4 bolts but it's not 'neccesary' (IMO).
Eric
12:40 PM
Scotland
If you have an M1 that certainly won't be type approved, buy buy insurance
12:40 PM
Lanark, Scotland
Errr, no.
Are you saying my/anyones insurance is void because I have a Dixon Bate adjustable hieght tow ball ???
I bet insurance companies love you....
12:40 PM
Errr, no.
Yes we are
12:40 PM
I don't think the 2 bolt version will get you the required drop. I was thinking of the 4 bolt version
12:40 PM
How much is the OE Grenadier towbar?
These days towbars are not cheap. On the Defender it cost me £800 for the removable one. The deployable tow bar was around £1300
12:40 PM
With all four bolts and the bracing bars to the chassis
