- Local time
- 6:56 AM
- Joined
- May 24, 2022
- Messages
- 353
it's the smaller little door protector. Fits on the inside of the bigger boot door to save damaging the little one if you close them in opposite sequence to intended. Replace with a bolt and large washer to stop the part coming off the bolt head as has done with yours. Search on the ground for a bolt. There's a thread on it on here somewhere.Hi. I have just found this in the back of the Grenny, I think it might have fallen off one of the back doors?? I cannot for the life of me find out wher it is from![]()
Common issue, add a washer to the inside of the rubber. It's from the larger door, it stops the door from closing on the small door if that is closedHi. I have just found this in the back of the Grenny, I think it might have fallen off one of the back doors?? I cannot for the life of me find out wher it is from![]()
See - Thread 'Design Fault'Hi. I have just found this in the back of the Grenny, I think it might have fallen off one of the back doors?? I cannot for the life of me find out wher it is from![]()
Hi thanks. That was the first thing I thought but that one is still thereit's the smaller little door protector. Fits on the inside of the bigger boot door to save damaging the little one if you close them in opposite sequence to intended. Replace with a bolt and large washer to stop the part coming off the bolt head as has done with yours. Search on the ground for a bolt. There's a thread on it on here somewhere.
I'll take around mine and see if there's a second one somewhere. Either that or someone else's Gren has parked where you park yours!!!Hi
Hi thanks. That was the first thing I thought but that one is still there??
Shit Bobby is 3min faster then me fair play!See - Thread 'Design Fault'
https://www.theineosforum.com/threads/design-fault.12413132/
Uhmm oke shit hahaha uhmmm you got a extra free one hahaHi
no two on mine. checked around a bit but couldn't see a spare.Hi
Thanks again I never knew there was 2![]()
That's one. Already have put a large washer on it. Couldn't spot a second 'sister' of it.Yes you have I have circled it View attachment 7829428
