The never ending alignment saga...
Zimm
3:50 PM
Pittsburgh
May be over...
When I went to pick it up, the truck was now pulling to the right but the shop was saying it all in the gree and they had gone thru the axle alignment proceedure twice. So a service tech had the idea of swapping wheel sides, and voila, it pulled left.
RDS gave me two take off tires, and the truck drives straight.
I've heard of bad belts causing this issue, but I've never experienced it.
The reason it showed up after the axle assembly swap (see other threads) is likely because I had them rotate the tires during the warranty procedure, and that moved the bad tore to the front, where it had been rotated out previously.
Hm.
Seemingly tires have a massive effect on the Grenadier. I've always known tires make the truck, but the Grenadier seems overly susceptible to different tire configurations. This might explain why some have problems and some don't. I know all the trucks with the highway tires drive vastly more normal than those with real AT's and MT's.
Maybe it's the super low caster?
