Technical documentation!
Thank you !
That's exactly the information we need. When I asked, my dealer told me that the large wheel hub nut needs to be tightened to 630 Nm instead of the required 375 Nm. That's quite a difference. I have a torque wrench in my workshop that can reach 850 Nm. But it's much too big and too heavy to take with me on a trip. A torque wrench that can reach 400 Nm is much smaller and can also be used for tightening the wheel nuts, for example.
Maybe it's overkill to use a torque wrench for such jobs. If, e.g., you're 75kg, you're using a 50cm lever, stepping on the lever end will give you 375Nm.
At least you got the email. Are they rolling the notifications out by delivery date? I ordered in September of ‘23 and took delivery in July of ‘24. 🤷‍♂️
My preorder was August 2023, delivery March 2024. Having said that, I can't imagine there is a rhyme or reason to this. I am by no means a super early preorder.
I received my confirmation email. Just now waiting for the username and password.
I registered twice. When the link was first posted on the forum and then again on Monday.
Curious if the new 13-inch MacBook Neo is adequate to run the online Grenadier technical workshop manuals. This would be dedicated to use for Grenadier. -- Thanks,
- 13-inch MacBook Neo
- A18 Pro, 6-core
- CPU, 5-core GPU
- 16-core Neural Engine
- 8GB unified memory
- 512GB SSD storage
- 20W USB‑C Power Adapter
- A18 Pro, 6-core
- CPU, 5-core GPU
- 512GB SSD storage
It is a web page. If you can run a web browser, you should be fine.
I run my access using a Lenovo MD11 El Cheapo tablet bought on special from the middle aisle in the local Aldi store. .. high class I am🤓
For your definitely upper class Mac book neo, it should be no worries :D Just don't get distracted by the interminable time it sometimes takes to get it to respond.. .
Think of NASA communicating with Voyager..
Ineos seemingly uses the same protocols ...🤬
