Suspension upgrade: 50 mm lift & Fournales Suspension' Oleopneumatic dampers... Verdict after 26 000 km (20% off-road) EN/FR
I think it should be noted, the stock units do quite a nice job. I don’t think the vast majority of reserve res shocks like king are doing a damn thing they were made for on these rigs, other than looking nice and machined. They have become a weird status symbol. How many grens are doing high speed running or are swingin’ 40”ers on the rubicon?
I have to say I think the standard shocks are pretty good. However If I was going to Africa or the Aussie outback I might upgrade..
These ones do sound good…
Well... I can only recommand to either try nimbus or fournales = oleopneumatic tech. In day to day ride there is a huge difference. The harder the terrain gets, the bigger you'll measure the improvements.
I wasn’t critical of the oly units, I know they make a tremendous difference. I’m referring to how good the stick units are when compared to high end standard shocks, that, if not under hard use, the owners aren’t really getting the primary benefit they are paying for. If you’re more the typical user, and adventure wheeler, the rerun on investment is in the Oly style units.
I know... No worry. What I mean is even if you don't use your IG for hard offroad you'll have a more comfortable ride.
I'm thinking upgrading my more classic cars with those shocks.
I’m into Mgb’s. I don’t need to switch… 😉
There are several members that own 2, actually a couple that own 4 & 5. Even to me that’s commitment. Guess I was just the lucky one. Try not to pick on me too much when I add the Quartermaster to the garage. I am jealous that you have the option of the diesel over there. Really wanted one with that engine choice.
Pick on you? Nah, but I'm still at Zero Grenadiers in my drive (kid's college expenses are killing me), but if one of your current Grenadier wagons needs a new home, I promise to take good care of it..
If one was not interested in doing extensive suspension modifications (heresy I know) but simply wanted an improved smoother ride on stock springs is there any point at looking beyond OEM shock absorbers at aftermarket units? There are some very impressive systems out there many suggesting an improved ride but compared to what type of vehicle configuration, stock, stiffer lifted springs, huge tires, etc…?
For example, if the mission statement for a given vehicle is not to be carrying heavy loads, bouncing off rocks in Moab or kicking up rooster tails of dust at hypersonic speeds across the desert is most everything aftermarket simply overkill or is there still a benefit to be had? It seems everything being advertised is canted more toward the “extreme” off-roader highly modified crowd but there are folks out there (admittedly few) looking for noticeable improvements but just not the extreme end of the performance scale.
