Steering Lock Up While Driving ( Highway Speed) UPDATE
74CampySuperRecord
10:08 AM
Arizona
I am asking this for my brother. He has been having an issue with his Fieldmaster’s steering becoming almost “locked” while making turns at highway speed on certain roads and bends.
He says it feels as if the power steering has failed. He has to “muscle” his words to steer the wagon. He says that it only happens on certain roads and on certain bends.
He took his FM to a local dealership and could not replicate it. Of course.
Talking with him an hour ago, it happened twice while I was speaking with him.
He also says that if at a stop. If he turns the wheels full lock. The steering tries to re-center? Some sort of resistance.
Any ideas?
Cheers.
Thank you. I will talk with him later this morning.
I also sent him a link to this thread.
My brother ran an OBD scan and the only fault code that showed was/is P0461. Fuel level sensor issue that he has had since delivery.
He said that the steering issue happens on the same stretches of road in certain locations.
His Fieldmaster is completely stock. No mods, except for Owl sidesteps. Factory 18” alloy wheels with BFG KO2 tires.
Are you saying it doesn't happen anywhere else? If that is the case get out and check the road by eye for imperfections/ruts. It is common where I live for the vehicle to tram-line on one section of road I use. It is on a bend, the road in question is a logging road with 44T logging wagons every few minutes. They move the tarmac into grooves that are difficult to see at speed before the tram- line gets hold of the steering.
Any ideas?
Cheers.
You should never try to turn the wheels on a hard surface while stopped.
High sidewall tyres will twist to some degree instead of turning and then twist back when you let the wheel go.
Worse if they are aired down a bit.
It isn't good for your tyres, wheel alignment or power steering.
That may be part of the problem.
He says it happens randomly on his commute. Something is wrong with his FM.
I will drive up to see him this weekend and experience the thrill ride.
or, just follow him.
Honestly, he is baffled and doesn’t want his wife driving it.
He is familiar with solid axles.
Sounds like the ESC is trying to straighten out the vehicle on those sections of road. I had that happen once while taking a sharp curve at speed. It also happened to me in a much more severe way on a rental Chrysler Pacifica. It almost killed me by forcing me into the oncoming lane! I hate this modern computer garbage in all vehicles.
I have a few left hand bends on the roads around me that always turn off the cruise control.
They are gentle curves but mid corner bumps on the left hand (outside) front wheel are enough to make the front wheel sensors note different speeds and kill the cruise control.
I now know they are coming and move my thumb over the resume button in preparation.
I am a bit confused about the wife driving bit...........why would your wife drive your Grenadier???
ESC only works through the brakes and has no input into steering itself
so thats what killed the cruise saturday.
And when the brakes are applied to straighten the vehicle, it forces a corrective maneuver. I think everyone knows it doesn’t move your steering wheel directly. It straightens the vehicle by applying the brakes. End result- the vehicle doesn’t go where you’re pointing it.
I know the physics of it but by the way you wrote your post I wasn’t sure you did as I have never had any vehicle nearly drive me into oncoming traffic or that much of a input caused by ESC , more of a slight guide than taking over the steering which is easily counteracted
Maybe the ESC on the grenadier is not well set up so is over done
My brother is now driving a loaner Fieldmaster from the dealership.
He says that the difference in steering feel is immediately noticeable after getting behind the wheel of the loaner.
There is something wrong with his FM.
I’ve also never had such a severe intervention from ESC. I’ve been renting Pacifica’s for years to do trade shows. This 2025 literally fought me through the curve and I lost.
The Grenadier has done the same corrective behavior on the same road but to a much lesser degree. I brought it up with the service manager and ironically, another Grenadier owner uses the same road and had the same complaint. It’s supposedly set off by the yaw sensor in the ESC. In the Grenadier it’s disconcerting, in the Chrysler it was a near death experience.
