Statistics/Poll Thread: Front driveshaft CV joint failures
Have my lift removed and a new front drive shaft installed by Regal. I will give this new setup (for me, vehicle had the 1.7/1.2 lift when I bought it) a chance, but if it fails again within 10k miles and no solution has been found to the issue of CV failures, I probably will have to look at another overland vehicle.
How did you make out after removing the lift? I have the same lift you have, and I'm having to replace the upper rear Rzeppa joint every 8,000 miles. I drive 1000 per week so it's pretty frequent.
It is at the dealership now and should be done later this week. They had to order the factory springs. I hope it'll last longer this time (the transfer case CV boot).
@Zimm. Mentioned a split boot as a solution so I hit Google and saw solutions as a band aids. They mentioned they will work on Jeeps so I figured might work on Ineos.
its exactly what i tried to figure out. is it just the boot or the entire joint? looked like the joint. So is crown just a cheaper version of rzeppa?
While occasional failures seem to have been recorded in most markets, the leading indicator seems to be a failed boot. One early case in Australia included a failed retention circlip. Failed boot->loss of lubricant->mechanical failure appeared to me to be the sequence...
I also wonder about driving styles:
There appears to be a higher occurrence (larger market?) in the USA
I regularly see reports by US forum members reporting cruising speeds of 75mph to 85mph or higher.
For standard 265/70/17 wheel tyre combination at 100kmh = 62 mph the wheels are rotating at approx 660rpm which with a 4.1:1 diff ratio equates to a prop shaft speed of 2700rpm
A cruising speed of 75mph increases this shaft rotation speed to 3250rpm while 85mph increases it further to approx 3700rpm.
There is an enormous deformation/torsional flex on the tight elastomer cv boot as is, due to its alignment. Increasing these stresses by a 1000rpm increase in shaft rotation at 85mph vs 62 mph surely must generate additionally significant heat and fatigue loads on the boot leading to the point of failure. This is exacerbating the existing increased stress loads induced by shaft alignment issues in vehicles with 2" suspension lifts.. where failure rates seem higher.
So.... alignment and shaft rotational speed.
Thoughts?
Thoughts?
Without checking your math you are 100% correct. The only part you are missing is the frequency of boot pinch based on lift height if any, terrain outside of highway or if towing heavy tongue loads. The boot pinch ultimately is the core problem on stock or lifted trucks. The shaft RPMs are the final nail.
Thank you for the clarification, you are spot on..." boot pinch" is a far more precise description (y) and is what I had in mind when referring to "deformation /torsional flex"🙄
I wonder how many failures have occurred in Europe , where 90-100 mph is often just the middle lane of the autoroute.
