Just wondered if anyone else is experienced a squeaky dashboard top in their Grenadier? Difficult to pinpoint exactly where it is squeaking from but it is fairly persistent!
Yep. Mine does. Very annoying.Just wondered if anyone else is experienced a squeaky dashboard top in their Grenadier? Difficult to pinpoint exactly where it is squeaking from but it is fairly persistent!
Without the metal clips, the silver plastic piece still stays in place?Pry off the silver part behind the screen and see if it stops. Mine squeaked and I removed the metal clips that held it firmly in place and replaced it without the clips and the squeak went away.
My dealership shoved a business card into the back of it to fix it.anyone with a solution to fix the rattle around the infotainment screen area?
The card is not visible?My dealership shoved a business card into the back of it to fix it.
It was.The card is not visible?
Ok I removed the two silver metal clips for the two center tabs… the rattle is gone!Pry off the silver part behind the screen and see if it stops. Mine squeaked and I removed the metal clips that held it firmly in place and replaced it without the clips and the squeak went away.
Arrghh now that the weather is getting colder my approach is no longer working. I'm going to try this.I can confirm that the link to the weatherstrip I used does indeed work. I used a 90degree pick and routed it all along the back of the screen in the gap and made two layers. The rattle has completely stopped.
Search the phrase below on amazon.
uxcell Silicone Foam Seal Strip, 2mm(0.08")
