Solar input to Ext Plugs
Levi
Quartermaster Owner
5:01 AM
Mollymook NSW Australia
Hi all, lots of searching and some open threads leaves me wanting to check this.
Has anyone successfully connected a solar panel (via MPPT unit) directly into one of the Ext plugs and had safe, successful battery charging?
I can see a lot of comments about this being possible, but the threads typically end without a conclusion or proven use case (happy to be direct to ones that do).
Context
I have the quartermaster trialmaster with dual battery set up. I picked up a nice little fold out solar blanket, 200W with MPPT unit. Plan was to swap out the Anderson to Deutsch and utilise Ext input on roof to plug in, currently have one spare, other running the fridge. Just looking for a top up on those longer hunting trips. Recently loading up meat, few days out saw my battery dip down for the first time and realised I need to have a bit more up my sleeve.
Not looking for a permanent connection, just simple plug and play when needed approach.
Thanks all,
Levi
Should be fine so long as your mppt is upstream of the Deutsch connector. IE install MPPT controller on the roof between panel and Deutsch connector. If MPPT controller is already connected to solar blanket you are fine so long as amps are in line with EXT circuit
That might be useful for maintaining battery charge if parked outside for extended periods?
haha, funny man Asnes!
Thanks for the reply. Very basic/simplified wiring approach attached, will report back after testing.
I have the Deutch plug connector tool, so will swap out the factory Anderson on the panel.
I killed the 25a Fuse with the charging, didn’t try again. Use now the charging points under the bonnet. No problem at all, Solar panel (240W) charge in 1h both battery from 45-100%, and after that battery “wellness” program: absorbing curve and holding charging level.
@Levi - How did this work out for battery charging?
Hi mate,
I have only tested a little, but so far it has worked. I have now set up Dual battery monitoring, and can track live and historically via a Bluetooth app. On a brief test, I can see it instantly lift power levels, and so far no issues with fuses, however, I need a longer duration test to be certain.
What I can say, is that with the Ext plugged in and PWR on i am getting battery charge.
Thank you!
I will definitely keep an eye on mine, i appreciate the input!
