So, knowing what you know, would you buy it again?
You should go check out the rear of a Grenadier…
I am constantly dealing with the size of the Gren cargo area. It’s not necessarily bad, I just seem to struggle with it, especially with a fridge! Part of this is the bulk of the seats, which is a positive for passengers but makes me want the commercial 2-seat version!
For the most part footprint means more than volume due to height. It's fascinating how its just like the G, in that I can't figure out how space utilization was so poor. I guess the same designers. I mean, I can put a platform in my fj60, and I can sleep on that. Not this. way too short. And I can fit a noticeable amount more in my LC 100. The load bay is wider and longer. I no longer have an OG defender to compare it to, but my recollection was a shit ton of utility space at the expense of passenger comfort.
That massive angled right side wheel well is less than ideal. It's like building a home onto a hillside. A swing and a miss.
[Posted by a bachelor who only carries around running sneakers in cargo]
"Heck, the older G-Wagons look awesome as a very similar spec vehicle for a cheaper price "
One of the things that's not a fair comparison with a used G-Wagon is the warranty (or lack thereof) v a new IG. Keeping that in mind, I hit the MBUSA site for certified pre-owned GWs and the cheapest there is $115k for a '21 G500 with about 45k miles. The CPO is a one year unlimited mileage MB warranty and you can buy a longer one. So while you can find GWs in the 60-70 thousand dollar range, you're probably on your own in that respect. I'm not saying that's a bad choice, but I imagine it's expensive to fix anything on a MB and that one year of warranty could be worths its weight since you'd have some time to identify any issues. Plus you'll most certainly need to lay out some cash for wheels and tires (that can do more than run over a flower box), bumpers, wiring for winch, lights and accessories, ladder, RAI, etc.
While I understand your point, I'm not sure they compete in the same space. Boxy, ladder frame, lockers, and overall generalish looks, yes. But the frames are different duties (think F250/350 v F150), solid front and rear axles (not any more as the GW is front IFS as of MY 2019), payload (~1700 to ~1100 depending on specs)... On the other hand, MB has more tech, much quieter NVH, nicer build tolerances, more/better developed software, and a much larger dealer network.
I'm not nitpicking or anything, just trying to give some perspective. Would I buy mine again...yes.
I'm 6'5" and I sleep in mine without issue.
Aftermarket platform, or gear stacking with inflatable pad?
Platform and drawers.
I definitely agree with this point and it’s a solid one. I am just trying to be open minded with the suggestions some of the Grenadier guys have made that are not the most happy with the drive shaft design.
The aftermarket doesn’t seem to really have a big following for the G Wagon, which is another concern even if I got a mid-2000s to 2018 or so, since that spans a few generations. The older I go, the cheaper it’ll be but more problems arise.
I do like the longer 5-6 year warranty of the Grenadier as a new vehicle. That does carry some nice benefits for a first gen model and working out kinks.
Not certain what you would be looking for, but there are a ton of places offering Gwagon stuff. Jack Wagon Off-road sells a fair bit. In fact many of the same big names making bumpers, rock sliders etc for the Grenadier have been making similar parts for the G for over a decade. Sure, you don't have Owl and Agile and such, but that's kind of a weird phenomenon that just happened with the launch of the Grenadier.
Most of the Gwagon stuff is pretty tried and true at this point. And the C-class engine in the previous generation is one of the best engines ever produced.
But, I will concede that repairing a Gwagon at a capable shop is not necessarily cheap. I am lucky that I can do all my own work otherwise I couldn't have a fraction of the vehicles I own. However the Grenadier will be just as expensive or more once the warranty runs out.
Only on the diesel ? The petrol one seems to have none.
Actually, humanity wouldn't function at all without labels. It’s how our brain categorizes things for survival. Not always correct mind you, and sometimes it’s a source of taking 10 steps forward and 9 back, but it clearly beats floating around unable to recognize, categorize, and label, like an amoeba.
I have to disagree. The primitive hindbrain and midbrain (the lizard parts of our brain) are the parts that reverts to simple categorisation for survival purposes, and the more developed cerebral hemisphere higher functions shut down in that scenario. If we are to behave like civilised humans rather than panicked beasts then it is our more developed higher brain functions that we rely on to do that and they don’t require categorisation as most of humanity is cleverer and more developed than that. The lower primitive functions are for emergency survival autopilot purposes. I would hope that most of us in this forum don’t rely on lizard brain functions for the majority of our living. Hence my opinion that the lack of need to categorise things / people in order to live in a modern civilised world is desirable. Just saying. 😁
See below summary;
The brain categorizes information for survival by rapidly identifying threats to trigger immediate, protective responses like fight, flight, or freeze. This categorization system, rooted in the older, more primitive parts of the brain, allows it to quickly process the overwhelming flow of data by assigning experiences to categories rather than analyzing each one individually. This allows for fast, often unconscious, decisions—such as labeling a speeding car as dangerous—to keep the individual safe.
The survival brain's 3 processes;
1. Threat detection: The brain's older regions, particularly the brainstem and limbic system, are highly attuned to danger.
2. Categorisation: Experiences are categorized as safe or threatening, good or bad, without requiring higher-level reasoning. For example, it quickly labels a speeding car as a threat.
3. Hormonal response: When a threat is perceived, the survival brain floods the body with stress hormones to prepare it for immediate action.
Fight, flight, or freeze: This hormonal response triggers one of three automatic reactions:
Fight: Confront the threat.
Flight: Escape the threat.
Freeze: Become still to avoid detection.
Higher-level functions go offline: During this survival mode, more complex functions like reasoning, problem-solving, and rational decision-making (handled by the frontal lobe) are temporarily shut down to focus exclusively on the immediate threat.
Malcolm Gladwell wrote a good book called ‘Blink’. Helps understand how and why we categorise or make judgments in the blink of an eye.
See below summary;
Ok. But this isn't going to put a oil level check dip stick in the b58 petrol .
Totally agree. I don’t mind the electronic oil level meter though. Call me lazy but i like it.
They are great I agree but the down side is significant
Dip sticks don’t lie and are exceptionally reliable
Electronic sensors are less convenient in that you can’t just check the oil at a service station, it must be done when the engine is cold before start up or wait a full 10-15 minutes.
They are more likely to fail, as all electrical sensors eventually do
When they do fail the sump has to be removed to replace them, not a simple 5 minute job, in the discovery 4 it’s a front differential removal and about 5 hours work
Give me a dip stick any day
I’ve had the electronic oil level meter in my BMWs for years. Oldest on I have currently is a 2011 model - 14 years old and still going ok. Assuming this is the same gadget then I’m pretty happy with the longevity. Agree dipstick and old tech is good, but reliability on these seems pretty good so am happy to not get stressed.
I'm not stressed about it either, but would hope that the dummy light is a separate sensor than the oil level, just to have a little redundancy in place in case of a catastrophe.
P.S. Nice looking truck! Love the color.
Do we not have access to a dipstick at all with the Grenadier or is it electric only?
