Should I ? - Wheels
ECrider
11:52 AM
And I never trusted a rattle gun. Overtightening ain't good either!
especially if anything like the ones my D4 used to have, I've had higher tensile chocolate!
chucked them all in the bin together with those atrocious locking security nuts. Now have solid stainless.
ECrider
11:52 AM
I've never used these. Any problems with galling?
no problems so far
this is the company;
8:52 PM
no problems so far
Some suggest a smear of copper grease, but that attracts grit and affects torque settings. Main thing is for the threads to withstand the forces!
ECrider
11:52 AM
I apply a smidge of copper grease and test tighten them everytime I check pressures or inflate/deflate. Does effect torque but I'm more worried about seizure than the little effect on torque values
8:52 PM
That's what I do with spark plugs and other fasteners ; nothing worse than a seized bolt or stud!
12:52 PM
Never ever lubricate screws before screwing them in. If they have no friction, any torque setting is invalid.
Spjnr
11:52 AM
Essex
There was a huge thread about this topic on Arbtalk (Arborist forum I'm on), as it relates to blade bolts on woodchipper flywheels.
Different manufacturers even were on either side of the argument. Someone's blade bolts had sheared off, and too much copper slip resulting in over torqueing was to blame. The manufacturer had blamed the use of the lubricant and voided the warranty.
8:52 PM
When you've had to helicoil the alloy block on an expensive Porsche V8 engine , because the old steel factory bolts (A total of 14 hold the water pump on) had galled themselves in, you realise that sometimes you have to compromise.
But by and large do what the factory manual recommends . A little antiseize or oil on the threads can save a ton of hurt later. As long as you know the metallurgy and are prepared to wear the consequences of your actions , I see no problem at all!
Spjnr
11:52 AM
Essex
Oh yes im in agreement. Just pointing out an example of how it effects torque settings substantially. It generally comes down to how often said bolt is being removed, for instance the blade bolts on my Woodchipper are removed at least once a month to facilitate blade change, so they don't tend to have time to seize up. Couple this with how catastrophic a 3kg blade breaking off and being sent through the spout by a 3000rpm flywheel is, it makes sense to leave the lubricant on the bench!
That being said, with other bolts that are staying in place for months or years, a bit of preventative lube wont hurt. As you say, as long as you understand the consequences
8:52 PM
There is a reason lawnmower blades always come with new bolts and washers!
12:52 PM
If a screw is lubricated, it can easily break off because the intended torque is not reached in time.
This seems to be a religious matter in many discussions. But I stand by my experience.
There is however a difference between oil and grease or copper paste. Copper paste contains fine ground copper and may be suitable in many cases. But I am still very reluctant to change anything if it will affect the friction values between a critical bolted joint. Especially when things like a cylinder head, an oil pump cover or the like are involved.
PS: Another confusion exists between lubrcation and mounting pastes. Mounting pastes usually contain friction improvers for the exact reason told above, which oil and grease do of course not.
Cheshire cat
11:52 AM
Cheshire, UK
Read a paper online from Bentley motors. The outcome was that lubricant was not a good idea on wheel studs. My empirical experience over 45 years motoring whereby I always used CopperSlip has so far never involved loss of a wheel or further torquing between services.
That said I don’t doubt the science regarding clean / dry surfaces being theoretically better.
Andrew Kilby
8:52 PM
Sunshine Coast - Australia
Hi
I have answered this several times and each time slightly differently.
  1. I am about to turn 60 and I am looking for a new car that will last me 20 years
  2. I will be moving to the country by the sea in January 2023
  3. The new vehicle needs to meet a wide range of needs such as
    1. long drives on the highway and back roads
    2. Visits to Fraser island driving on the sand
    3. gravel and dirt roads in the country, rural areas and national parks
    4. trips to hardware and landscape supplies
    5. picking up international business visitors from airport/hotel
    6. customer site visits at mines, treatment plants, construction sites and chemical plants
    7. Shops, restaurants and general running around.
    8. I like quirky and interesting vehicles only.
    9. Has to look good not round and bland.
    10. Needed to have a bull bar and driving light capability.
    11. Wanted a wagon not a UTE
  4. I spent two years test driving all sorts of vehicles and could not find a single one that met most of these needs, until I found the Grenadier on YouTube in February this year.
    1. Landcruiser/Prado - excellent vehicles but as exciting as the midday news.
    2. Landrover new Defender - I doubt will last 10 years let alone 20 and too much electronics and gismo's
    3. Jeep Wrangler/Gladiator- poor build quality, on road performance, safety rating and reliability that Jeep will stay in Australia
    4. Mercedes - GLC/GLE/G Wagon - too expensive and can't do any offroad in reality
    5. BMW same as MB
    6. Old Defender - seriously considered until the prices went stupid.
    7. Grenadier - seems to meet most/all of my requirements
I went through the same exercise and came to the same answer. I added in Toyota 70 series but only in manual and you can't order them now.
rovie
6:52 AM
I also use copper paste. That's what you learned in the past and it doesn't hurt. However, not in combination with aluminium rims!
8:52 PM
I never took the 70 series seriously as an option because it isn't something I could live with daily without spending another $25,000 on to make it comfortable.
You shouldn't have to add your own sound proofing, suspension and creature comforts to a car that expensive.
Shaky
6:52 AM
Whilst a agree with you, the same can be said for the original series I, II, IIA, III, 90, 110, and most of the defender iterations.
My other half had a romantic notion of getting a defender a couple of years ago, having never driven one. I told her to forget it.
8:52 PM
My experience from owning old land Rovers as well as Benzes and Porsches (much better metallurgy), If you buy a 2nd hand car where someone has bothered to clean the threads,
it's very likely someone will have used a wire brush , thus removing the bolt coating.
A recipe for corrosion and seizing.
Sooner or later someone will pop some grease/antiseize on.
I've never had a loose wheel bolt situation and I haven't always used a torque wrench.
If you buy a new car and religiously care for it and never drive in salty water etc , well that is the perfect world of textbooks.
