- Local time
- 5:25 AM
- Joined
- Dec 14, 2022
- Messages
- 111
- Reaction score
- 528
- Location
- Colchester & Sevenoaks
7Is there a prize if I can spot the 5 differences?
We spent all afternoon listing them. You’ll have to pop down and see them both at our event on Sunday.Is there a prize if I can spot the 5 differences?
These are the 18 inch BFGoodrich All-Terrain KO2 . The Grenadier on the right has the standard Bridgestone All-Terrain Tyre.@Eniffer Are the tires on the left truck stock size?
Thanks. The BFG setup seems to fill the wheel well better. Probably just the angle or something.These are the 18 inch BFGoodrich All-Terrain KO2 . The Grenadier on the right has the standard Bridgestone All-Terrain Tyre.
I see no white lettering on those BFG Tires. Is that a difference from the objectionable advertising found on the 17” size BFG?These are the 18 inch BFGoodrich All-Terrain KO2 . The Grenadier on the right has the standard Bridgestone All-Terrain Tyre.
I believe that is correct however I did see another post where someone had said they were reversible I.e you can put the lettering facing in. I’ll check that tomorrow.I see no white lettering on those BFG Tires. Is that a difference from the objectionable advertising found on the 17” size BFG?
They do look awesome.Thanks. The BFG setup seems to fill the wheel well better. Probably just the angle or something.
Mushroom is going to popular/common? That is the colour that I have ordered.Just need my Mushroom to be in the delivery bay now!
Depends where you live and what you do.Mushroom is going to popular/common? That is the colour that I have ordered.
It looks lovely in the metal.Mushroom is going to popular/common? That is the colour that I have ordered.
There is another you can’t see from the picture. I’ll give you a clue one has more torque than the other
You killing me....I have changed three times between white & MMIt looks lovely in the metal.
Don’t worry white looks epic as well.You killing me....I have changed three times between white & MM
