Safest lift with stock wheels
12:28 AM
Colorado, USA
I understand that there have been hundreds of posts before on this topic... but I can't find the answer to this specific question. I apologize in advance if I missed this situation.
I just purchased the 1924 Grenadier and would like to lift and get some bigger tires. My driving varies from highway to trails in the Colorado mountains but nothing too hard core.
I am looking for the most up-to-date recommendation regarding lift and tire size. I am looking to keep my stock 17" alloy wheels.
My plan is to have owl off-road install the the lift (they have assured they use the proper technique to avoid driveshaft issues)
I understand there is no guarantee that I won't have an issue -- but I"m hoping for some recommendations:
1) Is consensus that 1.7" lift is less likely to have issues than 2.5"?
2) what is the best/biggest tire size for AT tires with a 1.7" inch lit and the stock 17 inch alloys with no rubbing?
3) Does the 2.5" lift allow for any bigger tires with the stock 17 inch alloy wheels?
Again -- I tried going through all situations in the forum and couldn't find something that answers this directly. I believe most are changing their wheels as well. I apologize if I missed it and don't mean to waste anyones time.
Please let me know your thoughts. Thanks in advance.
1) Yes
2) A skinny 35 is probably your best bet, but it will most likely fit a 35x12.50, not saying that it is a great fit on the stock wheel however
3) Not really because at full compression the tire will be at the same place with any lift or the stock springs unless you are changing shocks/bumpstops
Not sure if the 30mm lift is available in the US but this is the 30mm lift with 12.5x33" 17"wheels.
The prop shaft angle looks ok.
I know a lot of people are raving about a 35x10.5 or maybe even push up to a 35x12.5.
FWIW: I have the Eibach 1.2/1.7 lift (or whatever it is)... with 285/75r17 (about 33.8" dia) mud terrain tires on stock steel wheels. The rears just barely rub on the rear portion of the rear fender liner when fully articulated. I don't see how a 35" tire, even one that is about 3/4" narrower doesn't rub.
1) Yes
Thanks Anand! What would be the the actual size/number for the skinny 35 on the 17 inch wheel?
There is a 35x10.5 and a 35x11.5
I purchased a trialmaster in September 2024 and begin the build this coming Monday. Back when I was gathering all the parts for my build, I purchased the 2.5" springs for the front but eventually went back and ordered the 1.7" instead. My hope is that the 1.7's don't push the limitations of the front driveshaft as much as the 2.5". I also prefer the look of a rake in the suspension so this was probably the way for me to go anyways. I really loved the look of the Braid wheels on the OK4WD and GP Factor trucks when I saw them at Overland Expo, and decided to go that route with some 35" Falkens.
Keep drivetrain stock and put on some AT 33”s (285/70r17). Why risk CV boot failure?
The grenadier is a mountain goat with lockers. Good driving skills will get you through all but the most challenging rock crawling without issue.
Enjoy the Colorado trails! I’m shifting my grenadier back to Colorado from Florida this summer :)
I was just told by my dealer in Pasadena, CA that if you change the tire size or shocks with "NO LIFT" this will void the warranty. Very frustrating when every sales person I spoke to, I have been looking at these for 2 years now, told me as long as you kept the lift 2" or less the warranty will not be void.
There is no such thing as a "safe" lift. The driveshaft pinion angles are the pinion angles and you only exacerbate them with a lift. There have been reports of bone stock trucks blowing through boots. Any lift will void warranty coverage.
It's a design flaw that IA will very likely not officially remediate via recall. Maybe they'll design it out in the next significant model year update.
This is VERY disappointing to hear, especially from a local to me dealership (RUSNAK PASADENA INEOS). They already told me to pound sound regarding the steering pump teapot whistle noise.
How would running a 33" tire cause any driveshaft issues? If a driveshaft blows and they deny coverage because of someone’s 1" taller tires, I'm selling the IG and never, ever buying an IA product again.
smh
No sales person, nor anyone at a dealer, can honestly tell you this as they are not the ones that are making the decisions.
The fact is that any modification has the ability to void the warranty if the manufacturer can prove that the modification, even in part, contributed to a failed part
smh
They told me the same thing about the power steering. Going to take it over to Matt in Irvine to see what they say.
