Rooftop Solar on Factory Rack
Wiring is complete from the panel to the battery box. I need to fine tune the cable cover, just not sure if I want to make a guide or cut the plastic. Not going to rush this decision. I will say this - fixing a roof rack to the lashing handles is a poor decision. I know, I know, add up all the M6 bolts and their load equals yada-yada. I call BS. I’ve spent a lot of time in that area and that is no way I would ever use that method for my typical roof rack use.
This little central bracket is where my MPPT brackets will mount. I loosened the two bolts on either side to center the factory bracket on the threaded floor holes.
All done. Tomorrow I’ll do some solar charge testing and see where my batteries sit (SoC) after sitting for three weeks. It will be nice to have an onboard supplement to the bogus smart alternator.
EGM is a modified version of AGM, so if there is an AGM profile use it. If both batteries are OEM.
My understanding is The OEM batteries are enhanced flooded batteries so the normal charging profile should be used,
EFB is a deep cycle battery chemistry like AGM, so AGM should be the better profile, verse sealed lead acid. Use EFB if this is an option.
I just noticed in the CTEK250SE manual, it has an EFB charging profile. Does the Victron?
I just looked at the Victron SmartSolar MPPT 100-30 manual. There are 7 charging profiles, including a couple for AGM. No mention of EFB.
I would ask Victron which profile to use for EFB. They have good after sale service.
My Victron chargers IP65 and IP22 both have 4 settings. Normal, High ,Recondition and Li-ion. And I’ve been using the normal setting.
