Roof top Tents
Thanks Pat. I took a look, but I am still unsure what will fit a Tentbox Lite XL given they say the bars need to be 90mm or less. I'm surprised at what a rabbit hole this has taken me down. I assumed it would be simpler!
Any details on why this size restriction? Maybe some details on the mounting itself ?
Because the mounting bracket for most RTT’s are usually a U clamp style and they are not wide enough to fit Rhino Rack bars because they are too beefy. You would then ditch the U clamps and use the T slot mount hardware which comes with the RTT and attach it to a mount which then attaches to the bars.
Some mounts sits the RTT flush to the bars. Some other mounts sit the RTT 2 to 3 inches above the bars which isn’t really aesthetically good and not good for centre of gravity. Some people also drill through the bars and fasten on the bottom side too.
also in may case Autohome is suggesting that the bar are 90mm wide but mine are 110mm instead. However they just took other clamps. My advantage was that the Autohome did mount the tent at their fabrication plant and I could discuss upfront and on site some logical options.
