Roof rack from Leitner Designs coming soon
It took me a couple of tries to get it together right as well, but now that it's installed, I think it's a really first rate piece of kit. I also got 2 gear pods during the sale, quite happy all around. Side note, I also purchased the Leitner bumper light mount, also fantastic.
No. Not in my experience anyways. The rear of the rack is the highest point as measured on my truck with no weight in the rear, to include when my safari windows are open.
I know this because I can clear my garage door by 1/2 inch and it's only closest at the rear (flat garage slab and less than 1% approach incline from the driveway).
After mounting my Leitner rack I had a friend on a ladder observing and filming as I inched back into the garage for the first time. One of Leitner's reps actually suggested that I give up looking for a rack if I want to keep the truck parked inside; turned into a measure 8 times and buy once scenario. Jealous of @ColoradoMike's door clearance
Any thoughts on how much higher the rear is?
If you installed it and it fit in the garage, why did the Leitner engineer try to dissuade you?
Just installed mine, with me in the driver seat the height at the rear of the rack is about 81 5/16 inches. Stock Bridgestone17s.
I am at 82" at the rear. 32.7" tires (285/70R17), which are about 1/2" taller than stock. so same as MTNDOG with stock tires.
That does help. Just want to ask if that is with the inherent rake to the IG, that the rear of the rack is still lower in absolute terms than the windows?
I kind of had given up on a roof rack, but trying to shoe-horn skis inside made me realize exterior storage is more of a benefit than I realize.
Is there a dedicated roof rack system for skis that work with this roof rack?
Do you have the cargo door ladder? You could try one of the DVM ladder mounts...
Rear Ladder-Mounted Accessory Carrier
Versatile Mounting Clamp
Has anyone gone with enough extra slats to make a solid floor? If so, how many did it take?
This has been asked a few times but I never saw an answer or photos. Can’t find any with a google search either. Maybe no one does that. It seems like you would need two bars to fill each 8” gap between bars. That would be a lot of bars.
Another question is since the bars are movable I imagine it is the front frame bar that keeps you from removing the safari windows if you have a full length setup?
I have read this entire thread and will probably go Leitner now that I see they have a side pod which I have been looking for. They have one called a pantry in Australia but it needs proprietary side mount system. I like this Leitner setup with many accessories coming out.
Still would love to see a platform photo. I like the idea of sitting up there in a chair. :cool:
I think you are referring to expedition hq pantry setup. I have one and works great. Could probably order just the pantry box and fix to the leitner side kick. Mounts with 6 or so small bolts.
That is exactly what I was looking at. Looks great! I wonder about the side box on my Defender but is very handy for some recovery gear, airing down tools, etc. I just did not want to be tied into their proprietary side panel. Also coming from Australia.
I was happy to see that Leitner has the Gearpod. Maybe not quite as cool but would work. Would not be sure about the Pantry and if the holes would line up with Leitner side panel until I got it here.
These Torx wrenches are awesome if you have Leitner ACS roof racks.
Turns out the conversion from 3/4 to full rack isn't as simple as adding lengthwise bars and moving the front end bar. The upgrade kit has the two lengthwise bars of the full length and a wind fairing. You add the front and back end bars, crossbars, and mounting brackets of the 3/4 to the full length bars to complete the rack.
I was wondering about this. So there is an upgrade kit? I also was wondering if you got the full and going the other way. The only issue I have with the full is that the windows don’t come out but I bet I never take them out. Also not sure if I need that much space. Possible the the full length looks better but with the windows you end up not really use it that front are anyway I bet.
The upgrade kit isn't available on their website. I sent a message to Leitner via their contact page and they responded, offering to send me an invoice for the kit. When it arrived, I was surprised to find two long bars, each 67", which matched the labeling in the instruction manual. I was puzzled because the 67" bars are too long to add to the front of the rack to make it a full. I realized that Leitner sent me full rack frame components. There are no short bars to add to the front to complete a full rack.
Full rack = $2600
3/4 rack = $1650
Full Length Roof Conversion Kit = $1050
Full rack = $2600
3/4 rack = $1650
It’s amazing to think that a quarter of a rack adds ~$1000 bucks. However, the fact that you can upgrade I think is great. I’m leaning towards the 3/4 rack due to the price point.
Late to the roof rack party but I installed my Leitner 3/4 roof rack two nights ago and absolutely love it! It was not an "easy" install as I am about a year out from a total shoulder replacement and had a really bad fall on it in September so my ability to lift things over my head is kind of spotty...LOL. I elected to assemble the sides, corners, and T-bolts BEFORE putting it on the roof. Prior to that I installed the brackets that mount to the grab handle areas. I then put a couple of moving blankets on the top so that my wife and I could get it on the roof. Once I secured the outer frame to the attachment brackets, I then proceeded to put in the slats.
I love the build quality! Everything fits like a glove and is very low profile! The instructions were very detailed to include the torque settings for the bolts! To me, it looks like it came from the factory. No disrespect to the Rhino Ineos Rack but it was too tall for my liking.
I elected to go with the MaxTrax universal mounting solution as they had a great combo deal for Black Friday.
For those of you curious about the height with respect to the safari windows I have provided some pics for your enjoyment!
If you have any questions about my install of it please hit me up, I would be happy to share. A couple of times I was SWEARING because the corners would NOT FIT! Well...chock it up to operator error and I misread the instructions. Long story short, the side bars need to "go into" the front and rear bars with a little bit of a PUSH. I was too gentle with it. Once I figured that out it was a breeze!
Enjoy!
Where did you get the hood contrast elements and the American flag lambda decal for the Grenadier rear logo?
Just installed the load bars waiting for a tent. Very easy install and looks super stout. Wish the bars were a bit longer though, maybe 3 inches a side so 6 inches longer in total. Would allow for more placement options etc.
How long did it take you to install the rack by yourself? My shop is quoting me a decent amount and I want to save some cost if I can.
Took half of a Saturday day for me to do it alone. The hardest part of installing it alone will be getting it onto the roof without scratching anything.
I used the copious amounts of packing plastic and cardboard to protect everything as I leveraged it up, using some saw horses to give me a “middle” spot from which to push it up and over. Having a helper would be best.
There is nothing about the install that is complicated, it’s a simple bolt-together design. You’ll want a torque wrench and torx sockets.
