For some odd reason, this mod interests me even though so far, the hump has caused me no issues.
I received mine today also, no template sadly. Will be installing it next week.Hi all,
I received my new footrest today, installed it this evening, and just took the Grenny out for a quick drive.
First impressions: I definitely had to adjust my driving position, which felt a bit odd at first. That said, the new rest actually feels really good, even though I didn’t go far. There’s more space to move your foot around, especially since I was wearing boots.
To be honest, I’d just started getting used to the original rest. Someone recently made me laugh when they said, “You only notice the hump is uncomfortable if you think about it while driving.” That’s exactly how I was feeling.
I’ll give it a few more days before sharing an update.
One thing I was expecting was a cutting template for the floor and rubber mat, but nothing came with the kit. Luckily, it wasn’t too hard to figure out. I just took it slow and made sure not to cut too much off. I started with a knife but found a good pair of scissors worked better in the end, see photos.
Cheers![]()
There is a template shown on the product page on the GrenX website, I can't get their small pictures to pop up in a large format so here is a blown up version. Maybe give them the feedback this template was not included Thoug
There is a template shown on the product page on the GrenX website, I can't get their small pictures to pop up in a large format so here is a blown up version. Maybe give them the feedback this template was not included with the product.
Really like the new GrenX foot rest, both my legs are now level when sitting and you can put your foot to the right of the rest, if you want to. The size of the actual rest is considerably reduced and it looks good. Also, seems to be firmly secured. Thought I would share more photos after the second day.I received mine today also, no template sadly. Will be installing it next week.
Hi all,
Cheers![]()
Sounds good @ROKY. Looks a bit more aftermarket than I was expecting. I thought from the early prototype pics it was going to be a full liner replacement but it obviously got changed to an insert.Really like the new GrenX foot rest, both my legs are now level when sitting and you can put your foot to the right of the rest, if you want to. The size of the actual rest is considerably reduced and it looks good. Also, seems to be firmly secured. Thought I would share more photos after the second day.
You're heading towards your own Sharon Stone Basic Instinct scene in that last pic.
PSA!![]()
I wasn't sure whether it would be a full replacement or not, but the photo did change on the GrenX website site. A full replacement would have better, but it looks better than any other mods I've seen.Sounds good @ROKY. Looks a bit more aftermarket than I was expecting. I thought from the early prototype pics it was going to be a full liner replacement but it obviously got changed to an insert.
PSA!![]()
The idea is fantastic to reduce the hump. However the execution could be 100% better. The original floor covering should be re-engineered with the reduction to keep the OEM look..I installed the GrenX foot rest and then went for a good drive, it has made a huge difference, it is far more comfortable to drive.
If you are like me and don't like ( hate ) the hump get one you won't regret it.
Easy to install all you need is a Texta, a Stanley knife and a pair of scissors.
Cheers
Steve.
No one likes the hump.When GrenX first showed the idea for this I was sure I would buy it. But oddly over the last few months I have decided I actually like the hump and the driving position
I like the hump.No one likes the hump.
What Hump.I like the hump.
It would be difficult to do a colour match as they are completely different materials. But having excised the hump from the original floor covering and inserted the new Grenx footrest what I can’t understand is why Ineos created this problem in the first place. Most of the excess bulk is actually in the floor covering. Ineos could have simply redone the floor liner and largely solved one of the main criticisms of the right hand drive vehicles.It looks very good but is there any reason they couldn't have matched the colour of the original matt and better than they have?
Totally agree. The part that has been done is great, however, the whole floor mat should be part of the revision. If not possible then a new matt to match the "hump reducer". Don't like the thought of my vehicle looking "bodgy".It looks very good but is there any reason they couldn't have matched the colour of the original matt and better than they have?
I wonder if it was the ergonomics expert that advised the exact angle etc. Bearing in mind the hump was a given. As I mentioned previously, the idea is appealing despite having absolutely no trouble with the hump.It would be difficult to do a colour match as they are completely different materials. But having excised the hump from the original floor covering and inserted the new Grenx footrest what I can’t understand is why Ineos created this problem in the first place. Most of the excess bulk is actually in the floor covering. Ineos could have simply redone the floor liner and largely solved one of the main criticisms of the right hand drive vehicles.
Great job.I have now had the flooring out for an other 500 km's. Have decided I like it better without, so making it more permanent. I used the remainder of my 1 sq metre carpet, and laid it on top of the closed cell foam that I placed earlier. I then cut out the bit of lining in front of the footerest that was still protuding into the footwell, and placed the carpet over, and tucked it under the remaining console lining, and front panel. Slightly modified rubber mat placed on top. I cut the corner where it was sticking up, Sikaflexed the overlap, and put a cable tie to hold it together. I lays flat now, and does not catch my size 12 boots.
