Reduced Braking Performance Scare
303ChickenMan
Cody
10:32 AM
Roxborough, CO
I had a scary issue in my Gren today. I drove up to 12,000 feet looking for elk on a very rugged 4x4 shelf trail. On the way back down, I got a “Reduced Braking Performance” and a red brake error light in one of the worst possible spots.
To keep it short, the trail was icy and I had already had a puckery slide, so I tried the Downhill Assist in a tight snowy corner. The pitch and roll were simultaneously very steep (probably 20-25 degrees down and side-to-side). Before I engaged the DA, I stopped with my foot firmly on the brake… and it didn’t feel right. I successfully engaged DA and got out of the precarious spot in a very low gear. Simultaneously I got the “Reduced Braking Performance” screen message in red and had the red brake system warning light on the dash.
The brake pedal could go all the way to the floor, it had some resistance, but would click as it engaged. I could also feel the click in the pedal.
I did what any responsible Grenadier owner would do! I turned it off for a few minutes until the center screen turned off and turned it back on and checked my brake fluid, which was full. I got one more funky press out of the pedal that then returned to normal and my warnings went away. I successfully drove the rest of the day and was unable to recreate the issue.
Was I scared? I won’t admit it. Should I have been? Yes. I had a long ways to go on that gnarly trail.
Can anyone explain what happened to my braking system?
Edit: I reviewed video I took of the descent. 1st and 2nd gear low were used for the descent. The throttle was used much more than the brakes (who wants to brake on snow and ice on a shelf road?). DA was only used for 20 feet. I had come down about 1000 feet from the summit when this happened.
  • IMG_4647.mov
    25.7 MB
Your brakes overheated from the long descent. The fluid boiled, creating air bubbles that made the pedal go soft. The click was likely the ABS system. Letting it cool fixed the issue. Use low gears and downhill assist earlier to prevent it.
I hope that’s the case! It’s within the realm of possibilities. However, I had only descended about 1000 feet and rode gears 2-3 in low range coming down. Who knows.
I agree with @rob88 . This summer coming off a 13,000 ft pass, the Gren in front of me was on his brakes a lot, they over heated and he had the same warning. Good to be warned before they fail. What trail were you on? I would like to get out again next week, but I worry there is too much ice. Glad you made it back safely.
That confirms Rob88’s suspicion! Makes sense. It’s easy to forget how heavy these things are. I was on Deer Creek trail coming up from Montezuma. It’s on the other side of Radical Hill and Webster Pass. No elk up there!
It’s pretty sketchy right now. There’s a few slabs of ice on the shelf road that make it very puckery. Snow isn’t too deep yet, though.
Fluid boils at lower temp at higher altitudes?
Yes! For example, water boils at 189 degrees (87c) at the 12,000 ft elevation I was at today. I’m sure the same is true for brake fluid.
Thanks, guys! Lesson learned.
If the brake fluid has heated to the point of losing pedal feel and getting vapour in the system it's probably a good idea to have the fluid flushed and replaced.
Racing fluid worthwhile? Compatible?
The downhill assist uses the brakes as well. I never had to use a DA on icy roads, but if the brake system heats up, that could also happen with the DA, as it also uses the brakes. Maybe you need to take other measures, as the DA is not designated to go down icy tracks.
Maybe it would be better to use snow chains and winter tires (if not already done) or tire spikes. Every system has its limit and a steep, icy track may be over the limit of every system.
AWo
The other factor to consider is the moisture content in brake fluid.
At 12000 ft water will boil at 90C or 190F.
Normally brake fluid should be changed every 2 years or 24k miles.
Off road use, especially in damp conditions, much more frequently.
Use a lower gear and never ride the brakes on a long down hill stretch
Number 1 rule when off roading
Glad you’re safe. If you do a lot of long descent driving at altitude- in addition to the suggestions above, you might just want to seriously consider upgrading your front brakes. It sounds like you were in low gear and trying not to ride them, so at some point, it’s just a question of the limits of the stock build.
That’s a great suggestion. I think the Grenadier is under-braked for my use. There’s only so much you can do after dropping it in low range and riding the first few gears down the hill. You still have to pulse the brakes to slow momentum. Thank you!
Yes - you kind of need some “mountain goat” support to the stock build. Often have those same issues here in Wisconsin on the Driftless Massif. I’ve gotta take that 50 feet of vertical at a slow crawl, which is rough when I’m getting lapped by a local farmer on a John Deere. White knuckler, let me tell you.
I am not convinced that an upgrade will make a massive difference.
Brake cooling primarily relies on airflow to convect the heat from the rotors which will undoubtedly be an improvement at speed.
At slow speeds the airflow is negligable so adding an inch in rotor diameter isn't likely to improve the situation significantly.
How much does the ambient temperature affect brake heating, I heard the comment about airflow, which I definitely agree. It just sounds weird that the brakes would overheat at such a low speed, even if they are almost constantly being used. At that low of speed unless you’re at an incredible pitch angle, there’s just not that much energy going into the brakes, plus it’s at freezing temperatures.
Maybe the downhill is sent is especially bad for this?
The standard brakes on the Grenadier are definitely not, optimal, to put it nicely.
The grenadier can display a lot of temperature and other data. Does anyone know if that is logged anywhere? I assume brake temp is one of them I haven’t looked at it lately?
Great point. Especially considering that this scenario consisted of sub freezing temps, snow, and icy puddles.
You would think that brake and engine oil temps would be in the temp screen in the off-road menu. I care way less about my tire temps than I do the critical fluids. 🤦🏼‍♂️
