Rear side window found partially open
Cheshire cat
6:09 PM
Cheshire, UK
On many occasions I have found my rear side (left) window to be partially open on my return to the vehicle.
Not sure if this is due to me hitting the door button as I exit. Generally open around 6 inches or 200mm.
Anyone else experienced similar?
I have accidentally touched the button occasionally, moving it down a bit. It was driver error.
I have, maybe 4 or 5 times in 2 years. Always rear left hand side about 10-20cm.
I’ve put it down to an ID10T error but also wondered if it was a glitch.
I have devised a test you can try.
Report your results.
