Rear Seat delete options
washingthegreaseoff
1:05 AM
New Mexico
Thinking about replacing the rear seats with a flat floor over the battery electronics. I know GP Factor and Goose Gear have kits available, but, I don't really need to replace the entire rear floor, just want a panel like you get in Europe with the 2 seat model. Does anyone else make something like this, or am I making my own?
Factory 2 seaters have a big metal battery box in the rear. That would not be an option I suspect. So you may need to make your own.
I have removed both seat bases in the rear. Has anyone deleted just the 60 side back rest and retained the 40 side? I would like to make the 60/40 rear seat an optional quick reconfigure if I needed only a single rear passenger.
It looks like cutting the steel frame is necessary, however without removing the complete assembly, I can't see if the seat back can be disassembled individually from the frame.
I haven't seen any photos of the 2 seat setup, but, I guess it makes sense. Huh. Oh well, looks like I'm building my own.
This is it, ignore water tank on left of image.
Drvier's side looking towards the cargo barrier. (RHD).
I added a gas strut to one side, so the metal lid is now very easy to open and shut.
As you can see the cargo barrier is attached to the big battery box at the bottom.
The water tank has a tray under it, so if it leaks the leaking water does not go into the battery box electrics, but to the floor of the car - via the green hose you see (one on each side of the tray).
What strength of strut did you go with? I found that one was not enough and added another on the LHS.
It is all about the pressure in the gas strut. I will try and find mine for you.
EDIT: Details here (50kg), the installer customised the pressure so it worked perfectly:
Not sure about the kg rating but I know have 2 x 150nm struts that work well - you have to be prepared to cut a metal support backet on the passenger side though. I'll check the kg rating vs nm.
Not sure about the kg rating but I know have 2 x 150nm struts that work well - you have to be prepared to cut a metal support bracket on the passenger side though. I'll check the kg rating vs nm.
Installer gave me the figure as 50kg.
