Rear Locker Failure Update
That may be simple. Eaton never assumed or maybe even considered the lockers would end up in rear ends that used cast gears. Those gears require a break in, which results in metal corruption of the fluid. Which in turn affects??? The wiring? The viscosity? The surfaces of the locker? No idea, and nothing we can prove or test.
Seems odd that this doesn’t crop up until at or after the first fluid change. My first instance was at about 13deg/f last year right before the 12k mile service, and nothing could be replicated. I’m at 22k+ and it is now every morning below 35. They likely thought I did’t know what I was doing Or talking about when I said the rear differential appeared to have locked and pushed me into the oncoming turning lane. I sure would have thought I fucked up and was projecting. I almost didn’t believe me. On two of my occasions, there could have been several damage or injury if the road was busier.
Wild guess.
I experienced a similar problem in a curve on dry pavement when the rear diff engaged. The truck wanted to go in a straight line. When the rear diff locks up the vehicle is unsafe to drive and should be parked and not be driven until it is repaired.
If this happens on a long trip it means your trip is over and you are going to have to find a way home and have your Grenadier hauled to the nearest dealer.
I love my Grenadier and cannot wait to get it back but this does raise a significant reliability issue, at least with me. INEOS must get this fixed and fixed right or it could be a big problem for them. One of the Grenadiers main selling points is reliability and they cannot afford to loose that.
Wild guess.
Eaton would be using forged differential gears, the internal bevel gears. Eaton has used this process for a long time. The crownwheel and pinion would have better final finish machining processes to eliminate operational noise when compared to the diff gears. Most diffs do have some sort of break in period from the manufacturer but it's rarely something any one considers in any new car or truck.
The locker is engaged by an electromagnet so when there is a large amount of fine ferrous material in the oil there is a good chance this may cause issues by accumulating in the clearances in the locker engagement mechanism when energised and not exiting when de-energised.
The few issues only a couple people have had with diff failures is more bad luck not a systemic problem with the axle.
Somehow I missed that it was your front diff locking. That does make sense for the loss of directional control.
At first i thought rear, then on a slow turn i had chirping front and rear so we thought center, then a week or so ago they said they were looking into the rear, and now… they are replacing the front. They are going to keep it and test it for a few days prior to hand over.
Does it always feel like your front though? There is a big feel 'difference' between centre and just and/or front. Or maybe it's intermittent so very diff to tell?
Ugh, it can happen on the front as well? I would think you could feel it. I could easily tell it was the rear. The other tell was taking it out of diff lock was difficult.
It lasts for one tight 90deg turn and goes away. Mostly I was hoping not to end up in an oncoming lane. It would just push straight. Any combination of 2 wheels locked will resist turning and do that.
Well this thread is upsetting. Its kind of a good thing they arent selling a ton of these things if differentials will randomly lock at speed, people will be seriously hurt
Mine is only locking up from the start first thing in a cold morning. I don’t think I could have ever eclipsed 20mph, if that makes you feel better.
Pretty sure mine tried to lock above 20 MPH, but not at a super high speed, and always during a turn. But I agree, not heard of one trying it at 50 mph plus. But, as they get worse we cant rule it out yet.
How can you tell it didn’t do it in the straight? It does make sense that a spider gear differential in speed could be the impetuous, but, my situation also requires cold temperatures, and not a “warmed up” diff, so, that may not be the case. It may happen on the straight and you just don’t notice?
Cannot be sure. Unsure if the warning lights would trigger going straight, or if they only trigger on a turn as the wheel sensors detect the same wheel speed. Mine has done it warm as well.
I believe the warning lights trigger when the wheel speed differential isn’t correct. So, if the rear is locked, but the computer says it isn’t, and the the two back wheels are turning the same rate but the fronts aren’t, I would think it would look like a rear end slide to the computer and it would step in.
The early mbusa Gwagon were so sensitive they would have stability step in if you merely went to bigger tires, and went around a corner, as wheel speed was out of the parameters. You needed a star computer to get in there and change tire sizes. It must have referenced them to speed of the truck.
In this case the warning lights are only a symptom. When they go off, you are having this mechanical issue. We actually did replace my speed sensors in Moab before we were sure it was mechanical. Some of the original ones fall apart fast, absolutely terrible wires. Replacements were a new part number.
Latest posts
