Ram Mount Projects
Loc Nar
5:53 AM
Alabama, USA
I thought we needed a home for Ram Mount projects and have one to lead it off:
Parts list:
2 2.5"x2.5" Ram Mount Plates (I went with the 1" ball, but there is also a 1.5" version here if you prefer)
T15 and T10 torx bits
Round Needle File (I bought this cheap set from Amazon)
2 M4 40mm black screws
6 M4 20mm black screws
8 black washers (12mm outside diameter)
1 piece printer paper, pencil, scissors, scotch tape
When I ordered my Grenadier without heated seats, I had in mind placing two Ram Mounts in the vacant spaces and after doing lots of dead end research and wondering if I was going to have to look into 3-D printing something, I finally found 2.5"x2.5" square Ram Mounts with a 1" ball and the four holes spaced 2" apart at gadgetmounts.com. Strangely, I had trouble finding these at rammount.com. It was only after searching the model number that I found them there. They're cheaper at gadgetmounts.com.
So, I ordered two of them from gadgetmounts.com and waited. While waiting, I removed the four screws from the console face plate using a T15 torx bit. The screws in the inner lower corners are much longer than the other three. When I received the Ram Mounts, I eagerly test fit them over the four holes and discovered the Grenadier holes are not quite spaced 2 inches apart and, as a result, I could not get the four screws back in. I did, however, figure out what type and length of screws I needed to mount the plate, taking into account the thickness of the Ram Mount. You will need two M4 40mm screws for the lower inner corner holes and six M4 20mm screws for the rest of the holes. They work perfectly and bite snugly into the holes.
To solve the problem of the Ram Mount holes not lining up correctly, I thought about widening the holes with a drill, but then decided that was too imprecise. So, I decided to do it old school with a round needle file. I picked up a cheap set from Amazon. I thought I might need the round and half round file, but I only needed the round one. After the needle files arrived, I cut out a square of printer paper, taped it over the holes, and made a pencil rubbing so I could easily lock down where the centers of the four holes were. I then cut the holes out and traced the holes on printer paper. I now had my guide:
I then lined up the holes over the back of the Ram Mount plate and, using a pencil, traced the area around the inner lower areas of the top circles and inner upper areas of the bottom circles to give me an indicator of where I needed to file down to:
With both mounts, I ended up not having to file down as far as I marked. I think maybe 200 vigorous strokes per hole was enough to get it done (TWSS). You can line up the adjusted holes on your printer paper guide to check progess as you go and eyeball whether you think you can get the four screws in. Each mount will take less than ten minutes of file work.
After confirming I could get all screws to bite through the widened holes into the console, I then needed to figure out what type of screws to use. Flush mount did not work (hole too big). I then tried Flanged Button Screws (ordered from Accu-Components) hoping they would cover the holes and they almost - but not quite - worked all by themselves. So, I ordered some black M4 Washers with an outside diameter of 12mm, and they were perfect. I tried regular button head screws also and they looked pretty good, but I just liked the look of the flanged screws sitting on the washers:
I only tightened the screws finger tight with a T10 torx bit and the mount is extremely solid. I did not use blue Loctite, but will if it turns out the screws start backing out. As for what I plan to mount, one will be for my Galaxy Fold 4 phone and the second may be for a Garmin device.
If you have done some other Ram Mount mods, please post them here (including installing any after-market options like Owl and others offer) with any install tips and pics. If you previously posted specifically about a Ram Mount project in another thread - please post a link to it here with a description. It will be great to have Ram Mount-centric stuff under one roof. I know some folks have posted about the Diamond 2-hole plate that works without having to modify the holes (and can work for those with heated seats!). If that's you, please post a link. Thanks!
The rail looks like a really good idea. You could get all sorts of things attached to it. It makes my attempt look kind of feeble.
My first go at printing anything with the Bambu Labs X1C. This is my new favourite gadget. :) It took me a lot longer to draw the stuff in Fusion (free version) than it did to print them. It's a pretty steep learning curve.
The first design was with a printed threaded hole to screw a 1/4-20 ball into and then an arm to a phone holder. My partner said, "Why don't you just print the ball as well?" so I did. The screw in balls have a rubber coating that makes it grip better but the arm clamped on the printed ABS ball seems to hold pretty good. I need to do some testing to see it will last.
Not everyone has heated seats so I did a version for that with the ball. The printed threads didn't seem all that durable so I got some threaded inserts that press melt in with a soldering iron. Doing a tapered hole just the right size for the insert took me ages to figure out in the software.
I haven't figured out how to attach .stl files to posts. It shows an error when I try. If anyone wants the .stl files just let me know and I'll try and figure out a way to post them on here.
The original cap head bolts need to be replaced. It takes 3 x 4m x 16mm and 1 x 4m x 40mm.
Can you post pics of the screws you used? II have some that are M4 coarse thread, but they are not the right coarse thread. They are called “self tapping plastic” screws, so I’m afraid that I’ll tear up the holes?
Also, what is this RAM ball system???
I got the agile mounts.
I used to have the shelf from eBay with ram Ball mounts. I didn't like it as much as I thought so I updated it to the agile mount with bullet point arms and phone holder. Like it better
Does anyone know the IP around the RAM ball system? I mean it is a ‘ball’ but the size and use?
Just standard M4 as far as I know.
I'm not sure about the RAM ball system. The phone clamp I got is for a 1" ball.
Oooo. That looks nice.
I thought I'd put my new 3D printer to work and had it print 9 of the things I managed to draw out in Fusion. I've got a few left. Message me if you're in Australia and want one or two. Because I can never seem to have enough fasteners, and it's not that much more expensive to buy more than you need, I've got the M4 fasteners bolts in 316 stainless as well. Printed in ABS plastic.
That looks really impressive for a 3D print. How big is the hole? I dont have heated seats but am thinking of mounting a USB outlet where the switch would be. If you still have any left, I would love to try one.
Heat press that brass fitting?
On the screws look at the oem ones. For US ‘25 models, they are a coarse thread, how are your original screws? I worry that the wrong threads will jack with the hole and degrade the holding power.
What kind of screws come with the commercial version s?
Very, very nice. Looks real professional. Red filament?
Looks like a quick brush with acetone would really smooth out that print for a really nice finish.
You can’t mount a USB port unfortunately.
Right behind it is the printed circuit for the entire switch panel. Regardless of heated seats or not.
Yea, red ABS.
I've read about the acetone treatment. I might give that a try.
You mean this one?
I have not pulled mine apart yet but wonder if it's possible to drill a 23 mm hole through without messing up the circuit board.
The hole is 41mm.
Like IslandFalconer said, there is a huge circuit board behind the panel. I wanted to put a RJ45 through connector in the panel but the circuit board put a stop to that.
I did one of these just to see what it would look like. You can have this one if you like. Message me your address.
Yea, I dug out an old soldering iron and filed the end to fit the insert.
Your screw question sent me on a journey. I'm sure I had thread pitch gauges in my toolbox at some point. Where they went after the move to Australia five years ago remains a mystery.
I think the stock original screws are standard Metric M4 with 0.7 pitch, which is the size I'm using for the longer replacements.
On the left is a screw taken from the horizontal panel next to the cup holder. I recon it just goes into plastic so it doesn't really matter all that much. In the centre is one of the original cap screws. On the right, one of the replacement cap screws I'm using.
I tried the original screw in a standard M4 nut and it fits just fine like I would expect, as do the replacement screws I'm using.
