Power steering noise
Eric.S.
5:30 PM
Thank you;)
Centering isn't as critical on Yota and rover because the CV joint is centric on the wheel spindle via a bearing or bushing depending on specific build. The CV joint is in a sealed knuckle or swivel ball. The Grenadier has an open design with a Double Cardan. This requires the shaft be fixed or centered on both sides of the joint. I have already seen gauled shafts on Grenadiers.
I disagree - in part. Because the inner axle on Toyota front ends is sealed at the outboard end (and bushed) there's no room for offset at the other side of birfield. Everything has to be kept in perfect alignment. 90wt is kept in the axle housing and grease is isolated inside the ball by the seal I posted a link to. Dana axles, for example, are sealed just outboard of the diff and a royal pain to replace. But they don't fail often because there's no play so close to the differential side gears.
When I look at the image that @Logsplitter posted it looks like the Carraro axles are also sealed at the outboard end just like Toyota stuff. I can't tell for certain. It would be cool if they are because the third member isn't removable as with Toyota.
Expect future version of the Grenadier to come with a redesigned axle with CV's someday. To be fair I like the Cararro axle, I just don't think it's going to win over the masses and is expensive as compared to more traditional road going vehicles like Rovers and Yotas.
I'm in no way opposed to improvements. Here in the US we'd all probably prefer a Dana 60. I get that. But I'm not always happy with closed knuckle designs despite their resistance to dirt and debris entry. The problem for me with them is that you can't tell what's going on until the things are fairly well advanced so I'm not wishing for that either.
I'd like to live with the Carraro front end long enough to know how it fares. It could prove to be outstanding. It sure looks strong. Galling would be a metallurgical problem easily corrected with a minor materials change - not a total redesign.
Upvote 0
Gauling in this case appeared to be due to misalignment. There is a huge bushing and seal on the axle side of the knuckle. Any misalignment will cause the shaft and bushing to fail.
And as for Yotas, same design as Rovers more or less. The axle seal is at the end of the tube. We often removed them and converted back to old school oil in both the axle and swivel balls, even removed the inner seals. Rover only introduced grease in the swivels to the USA in the 90's round about. They were damn proud of their one shot grease packets. I know all this because I was there and a tech at the time. Best I recall was because the oil leaked to easily. Anyways, the inner seals on the rover and yota have a huge allowance for misalignment in relative terms. They have to so that the seal holds up when the axles flex under max loads. I assume you realize your yota axles bend a bit when loaded right. That's partially why Yotas were trussed a bit to reduce this and help with leaking axles.
When I built axles professionally I used huge alignment bars that were 1.5" thick. You could easily slide the bar from one spindle end to the other without any interference, smooth as silk. But man if I used the wrong kind of seal at the ends of the tubes I would hear about it from customers. I learned that lesson quick. Axles flex far more than you can imagine.
Upvote 0
My '97 Land Cruiser lifted on 37s with a brand new OEM pump and OEM steering box steers like a 911 compared to my new IG. The IG has zero excuse for the slow return to center, wider turning radius and movie car steering corrections when a nearly 30 year old truck can do everything better in the steering dept.
My local Pasadena dealer service rep told me the squeal needs to exceed 90 db to be considered for a warranty replacement, but even then there are no guarantees that the new pump will be silent.
I conjecture that IA knows there is no fix except to go back to the supplier and ask for an entirely new de$ign. This is why they're dragging knuckles at our expense.
I've come to accept it (begrudgingly) because I'm not dropping $3K on a new pump plus labor to end up back at square one. I'll give the min level cold a try because max level cold made zero difference on mine. There's split bro forum science here whether high or low fluid level will actually eliminate squeal. Make up your mind internet. lol
Let's keep this thread going with more owners voicing their displeasure. Rock on!
View: https://www.youtube.com/shorts/T4atrIgFlg8
Pasadena dealership said the MY25 have a different part number for the power steering pumps and are much quieter, and the parts won’t work in THE MY24 trucks. 🤷🏻‍♂️
Upvote 0
We have owners here w MY 2025s with the whine no different. Not sure where they’re getting that info from.
Upvote 0
This morning, the temp was 55 and my PS fluid sits right above the min line. I am a lucky one with already less noticable whine. Today almost non existent in terms of sound. We talk about the pressure and how the pressure build up may contribute to the electric motor needing to do more work. I wonder if with cool temps will people hear a quieter whine now.
Upvote 0
I confirm yes it does. Also tyre pressures should be at 36 psi (unloaded, cold) and the steering feel and weight is perfect. No need for a fancy steering damper.
Not many people believe this, everyone else thinks we’re talking nonsense because we don’t have the science to back it up but I have a bottle of BMW steering fluid and been experimenting. If you fill upto max and even slightly above. I can hear it whining from around the block and the steering is so heavy especially in hot weather. The whining doesn’t bother me so much, it’s the 10 point turns which bothers me and my Mrs.
The steering reservoir doesn’t have a return pipe just one pipe so it’s slightly different than conventional ones. Some have tried it, It works for some and not for others 🤔
Upvote 0
Do you fill it when the engine is hot or cold?
Always cold. So early morning, use a turkey baster or large syringe to take out some fluid out, level with minimum. Use a towel to wipe the indicator level on the cap to get it accurate.
Tyres ideally 36psi cold if it’s not laden. 38 to 40psi if full rack on top.
If it’s doesn’t work, get some Fuchs Titan for formerly Pentosin CHF11S (from Amazon) and put it back in.
I hope it works for you.
Upvote 0
I don't have any PS noise. Just checking your method as these things vary!
My old 911 oil level is checked with the engine warmed up and running ; the old Benz auto trans in a similar way.
The owner manual should always state these things in plain English. Or French if that's where you're from, etc 😀
Upvote 0
If you don’t have any PS noise then I would not change a thing. How’s the steering then? Light or very heavy? Does it feel like a 911 around corners 😂 or a boat?
Upvote 0
