Ordering and price book
Rockpool
11:26 PM
Fleming Island, FL
I thought I had the options list cracked - I am looking for a 2026 Trailmaster with, amongst other things a winch, or at least the "Winch Prep" option - ie nato plug at the back and winch hookup at the front - I've seen a bunch of them with no nato plug and no "winch prep" listed on the window sticker.
Today, I found a 2026 Trailmaster with nato plug and NO winch prep listed on the build sheet...
wth?
wth?
Prior to the MY26 model year the High Load Aux Switch Panel and Elec Prep option which had the NATO plug, included the front winch prep. But for MY26 Ineos have taken the front winch prep out and made it a seperate option.
Cheers
Steve
I thought that as well but no - build sheet is for a 2026 Trialmaster. I guess my point to future buyers is - you can't trust the build sheet or window sticker. If a winch is in your future, make sure you see the redwinch disconnect under the hood on the left side, and the nato socket on the back.
What does the redwinch disconnect look like and can you see it without disassembling the front fender area?
I ordered a 2026 trialmaster with winch prep. It has the nato plug, but as noted, the window sticker doesn’t specifically state winch prep. I suspect it isn’t there, but I thought I had to look behind the passenger side (LHD) headlight to find the switched terminated connector.
There will be a 150amp auto reset circuit breaker in the engine bay for the front winch. For a left-hand drive car look for it between the air filter and the high temperature coolant reservoir. On right hand drive cars it’s next to the positive jumpstart post. The Rok_Dr manual has engine bay illustrations.
Cheers Steve
  • Well done
Reactions: Max
