Orange check engine light
landmannnn
3:35 PM
UK and France
After several hours on rough gravel tracks I stopped for 10 minutes or so. Restarting the check engine light appeared.
The codes were pending transmission fault and pending communications error.
I cleared them and it didn't come until now
P248F which appears to be her cooling circuit
U0418 which appears to be braking module
Any cause for concern?
Always make sure your transmission is still there, if so you are good to go;) Really I wouldn't be to concerned until it comes back again, then I would leave it one stop by the shop.
I cleared them and it didn't come back.
I had a red transmission error in Morocco after the Tuareg guy I gave a lift to fastened the seatbelt behind him without wearing it, then got out and left the seatbelt buckled up with no occupant. The computer didn’t like that and warning to say transmission fault stop immediately in red with red triangle warning. Slightly concerning at the time until I sussed out what had caused it and locked the car and left it for half an hour.
Ok. It might be unhappy that I have been running tyre pressures in the low 20's for a week or so. I couldn't seem to reset the cold pressures so i
Made me think a bit
I've been running tyre pressures in the low 20s so showing a warning. (I couldn't seem to reset them that low)
So I pumped up the tyres, cleared the code and it now doesn't seem to be throwing the code.
The code came back up again. I've asked customer services if it is ok to drive for a couple of months with this EGR bypass circuit pending fault.
I will wait to see what they say.
Pretty poor response from customer services - guessing they are outsourced and have no knowledge.
It appears to have been a crack in the EGR valve pushrod after close examination. Bodged with a cable tie and epoxy glue for the time being.
I wonder if IA will post me one? I am not holding my breath.
If I remember rightly, mine snapped and was replaced, during that time it used more Adblue
