Oil temperature ?
Tinki
8:31 AM
Hello Team ,
Not entirely sure the implications of this but here it goes .
As mentioned before on the forum i try and do an oil change every 3k miles for the Gren .
Now due to factors and circumstances out of my control i pushed back my last oil change to 6k miles .
I tend to keep an eye on the engine oil temperature both during driving and when stationary after a long drive .
I have some anecdotal evidence to present .
Over the past few months the car has been driven mainly at highway speeds and for at least one hour each time , almost no short trips . During the cars life the oil temperature never crossed 102oC , on highway under load doing 79MPH (17oc outside temp) temp used to be 94 oC . I noticed this to be a bit higher than previous ( at least a couple of degrees) .
I changed the oil at 6k Miles last week no obvious oil dilution, it looked like 7 Liters came out , 7 litres went in .
I drove close to 800 miles this week . Mainly highway speeds. I have noticed that at highway speeds 79MPH , outside temp 27oC oil temp is now constant at 89oc . Once stationary it will climb to 99oC .
My question is what is the brain hive's experience ? Does the oil degrade causing the higher temperatures ? Is this significant ? Does this mean anything ? How hot have you gotten your oil ?
Again this might be nothing , I do not have enough data to support a hypothesis , but rather an observation that might lead to something .
Keen to hear your thoughts and observations .
102c is not a problem for modern high spec oils. I recently had an air cooled motorcycle engine showing 142C oil temp for a full day with absolutely no problems. I was way too hot really but I had no choice and running on a modern high spec fully synthetic oil there was no damage done. I changed the oil after and it was still like new. I wouldn’t have done it with a mineral oil which will really degenerate after 110c
Hello Team ,
Diesel motor
I found the ambient air temps did not greatly influence the oil temperatures (between 10c and 30c).
I think air flow has a greater influence on oil temps, and how hard the engine is working. The BMW engine runs hot and the oil temperature moves up and down a great deal more than my old Patrol.
Oil age does not seem to be influencing my oil temps.
I was able to understand the Patrol's oil temps better than the Grenadier, which can be mysterious at times (maybe the DPF burn off is the cause).
Modern oils High temp high shear HTHS test is done at 150C. Engine oil will increase in viscosity if there high soot and contamination loads but it generally decreases with fuel dilution and viscosity break down. Higher viscosity oil will run at very slight higher temps. Temps for oil at idle after working the engine will increase for a short time then decrease.
I observed considerably higher temperatures, see my post. I still think this isn't normal.
Tazzieman, don’t you have the oil temperature display in the off-road page with your petrol motor?
Wow, I wasn’t aware of that. It seems really daft to not have it on the petrol engine
One for the knowledgeable: Which modern petrol 4x4s come standard with oil temp gauges?
Next to none because there would be too many people complaining when the oil in modern engines can push 130C+. The same reason temp gauges don't move much in normal operation. A cooling systems will push to 110C these days. Transmission oil temp can push over 120C before a fault light comes on.
That was my understanding too.
If people want to chase their anxiety , exploring various parts with an IR gun can assist 😁
Or an OBD tool.
I trust the Grenadier has been engineered to cope with a variety of loads. User error such as overloading or allowing componenrs such as radiators to become damaged/ blocked is what it is. Ignorance!
Or an OBD tool.
Sharing, not arguing.
Sometimes folks just like to know what's going on.
Years ago the Sikorsky company trialled a mock helicopter instrument panel that took away all green/white, normal, good, expected indications. The hypothesis was if it's a normal or expected condition there is no need to display it. If something goes from normal to an abnormal condition, like a rising gearbox oil temperature, then display an amber or red indication as appropriate.
The trial crews hated it.
Paranoia is ops-normal for helicopter crew and particularly crew operating over water.
The trial crew fixated on the blanks:
'Is it off because everything is normal or is the system broken?'
'How do I know the monitoring system is working?'
They were happy to keep scanning the additional information as part of maintaining situational awareness.
The trial contributed to Sikorsky's development of the Vertical Information Display System (VIDS) introduced on early UH60 aircraft to condense operating data previously displayed on analog gauges, into vertical illuminated LED display stacks that could be scanned horizontally by the crew. The VIDS concept later evolved into digital Multi-Function Displays (MFD) that are common on modern aircraft.
Guessing a helicopter pilot is way more switched on mechanically than the majority of drivers and gravity is a major part of the paranoia.
There are a lot of 12 o'clock gauges in machinery with green and red markings. If the needle points near 12 o'clock at a glance all is ok.
Decades ago when I was more "anal(ogue) retentive" than I am now 🫣 it was common to adorn one's new (= pre-loved) 4 wheel acquisition with a cluster of Smiths/VDO gauges to replace idiot lights... One might then if truly keen, rotate all gauges, including the tacho (rev counter) and speedometer such that when cruising at the open highway limit of 60mph, all gauges would be pointing vertically .... half the entertainment was in actually installing said gauges..... Ah!the joys of a carefree youth!😜
Still got my old Land Cruiser with extra VDO gauges fitted, Pyrometer, oil pressure and boost. During my apprenticeship you had made it when you had working Murphy gauges in your old 80s model 4x4.
Smiths gauges over Lucas 'Lord of Darkness' electrics. They were troubled times @DenisM although it kept us in good shape walking back home.
🏴󠁧󠁢󠁥󠁮󠁧󠁿 designs have come a long way since. Oh, wait... 🤔😫
I'm sure the enthusiast can find a way to plumb in an exterior oil temp sender/gauge.
If it's in the ECU then it's likely accessible via any of the OBD2 dongles. For those that REALLY need to know, y'know?
It's like adding an aftermarket turbo EGT gauge. Mildly interesting in a geeky way but of no useful value without temperature limits.
Egt gauges are a helpfull diagnostic tool. Most well tuned engines run roughly the same exhaust temps. Most of the gauges available for new trucks connect straight to the CAN BUS as most trucks use the standard J1939 protocol. Not sure what protocol Ineos uses but likely there are kits like Scan Gauge that will work.
