General Oil check
Ineos1NZ
Contract Signed
10:41 AM
NZ
It is perhaps the same as mine, saying test aborted when in fact it has been completed and is ok.
It has been forwarded to the factory for the wording to be altered.
I will check mine when I get it back next week to see if the updater has altered it,
When I got back from collection I checked and it advised add 500 ml, the following week it advised add 500 ml so I have added 1000 ml since pre delivery inspection and have travelled less than 1000km
I have tried a further 5 times and each time the oil check procedure aborted, I share your curiosity in how much oil we have in our engines?
Ineos1NZ
Contract Signed
10:41 AM
NZ
Think somebody already mentioned cross referencing correct oil level via refill/digital gauge and then viewing where that registered on the dipstick. Whether that marries up well or not remains to be seen.
DenisM
8:41 AM
"To Dip or not to Dip one's stick" ...an existential question for the B57 diesel...
Today I embarked on a discovery mission to actually find the elusive dipstick ...
First put the bonnet/hood in the maintenance/upright position. This is a straightforward exercise (it helps to lightly lubricate the grommet in the pivoting brackets to facilitate removal/re-installation...
Next: remove the engine cover. Takes less than 10 seconds : carefully lever one corner with two hands then proceed around the perimeter carefully levering the plastic extrusions from the o-ring receptacles...
What a sight to behold!
The dipstick cover is located slightly below the level of the "faded yellow" plastic collar as per the blue arrow
Close up below ---second arrow shows location of oil filter casing. The requisite fastening torque 25 Nm is engraved on the top of the screw-on cover
Below are close-ups of the dipstick in detail
Yes...it has oil... and seems quite full ...though the magic computer indicates it needs another 500ml for both on road and off-road! (after 6,200km).
dipstick end.jpgdipstick ID Markings -1.jpgDipstick ID markings -2.jpgdipstick label.jpgdipstick receptacle.jpg
Dip stick receptacle
Other "finds"...
sorry for the poor quality of the pics... the macro function on my Samsung 10+ isn't real effective:
Tried to capture the view under the LHS mudguard/fender. When I pushed down from above the metal flexed ever so lightly then I could feel something quite solid underneath. Under the top mudguard/fender panel I could feel a second metal panel...much thicker. Then there's what seems to be a thick solid "pillow" of (guessing here) some sort of black thermoplastic? material which fills the void and distributes any weight resting on the outside of the top panel...I didn't have the courage to "dismount" (Hi JM! 😎 ) the mudguard/ fender to find out...
The flat area of the mudguard/fender is quite a bonus. I'm rethinking my original decision not to option the alloy plates. Maybe a cut-to-size section of thick clear vinyl wrap will do for the meantime 🤔
8:41 AM
@DenisM it's as tight as a fish's arse back there! And confirmed my petrol one has no dipstick.
MrMike
6:41 AM
View attachment 7843071View attachment 7843072View attachment 7843073View attachment 7843074View attachment 7843075
Other "finds"...
View attachment 7843077View attachment 7843078
That thermo plastic is Polystyrene
ECrider
11:41 PM
Other "finds"...
excellent photos and info. tks.
I wonder if that polystyrene is the 'reinforcement' that comes on RoW cars, or whether there's even additional reinforcement when optioning the chequer plate. Bit of a mystery still. Will have a go locating my dipstick - ooer when the weather dries up. Will be good to know what the base measurement is when full. Though my computer still asking for 500ml refil for offroad when it's had close to 8l!!
DenisM
8:41 AM
Under the top external panel there's a rigid metal panel, certainly significantly thicker than the exterior one. The polystyrene sits directly below this. Need to remove the wheel arch cover to confirm the structure....
ECrider
11:41 PM
Thank you. Will have a look under mine. My wings are very flexible, you would not want to put anything heavier than a claw hammer in the middle.
Rok_Dr
6:41 AM
Perth
Other "finds"...
Great info @DenisM, thanks for posting.
