Americas Oil Change Reset
You can clear the oil change reset with the Ancel BM700 can clear the engine oil light. This is one of its primary functions, as it is a diagnostic tool specifically designed for BMW, Mini, and Rolls-Royce vehicles.
The feature is typically found under the "Service Functions" or "CBS (Condition Based Service) Reset" menu within the scanner's software. After performing an oil change, you can use the BM700 to:
  • Reset the Oil Life Reminder: This turns off the oil service light and resets the vehicle's internal computer so it can begin calculating the next oil change interval based on driving conditions and time.
  • Clear Fault Codes: The tool can also read and clear any related fault codes that may have been stored in the vehicle's engine control unit (ECU). So, if you need a scanner for your BMW to reset the oil light, the Ancel BM700 is designed to perform that function. If you buy the Ancel BM700 do not get the "PRO" model. This Pro model will scan your Vin, our Vin is Ineos not BMW. With the Ancel BM700 you can quickly get into your vehicle's systems by following this cheat sheet. I love using this device.
  • BM700 Menu Path for Grenadier
    1. Main Menu → BMW
    2. Manual Select (skip Auto VIN)
    3. Passenger Car
    4. 3 Series
    5. 2021–2023
    6. G20/G21 (this is the BMW 3 Series platform closest to the Grenadier’s ECU layout)
    7. Select All Systems scan
  • Tips for connecting successfully:
Interesting, G20/G21s are "mild hybrids", and the transmission sump pan for those and the Grenadiers have a second, smaller uptake port that all other BMWs don't have. I wonder if all of the G20/G21 ECU signals / codes / actions are identical to the Grenadiers, or are much more 'overlapping' with the Grenadier than a 'regular' BMW with a B57/B58. I don't know why we have to read the tea leaves to figure all this stuff out, I am becoming more chaffed by this as time goes on. I'm waiting on my account for accessing the maintenance manuals online so I can sort all this stuff out.
This is the problem with proprietary s/w, fought this for 30 years at AF and NASA from vendors. So INEOS went with / had to go with a vendor proprietary solution that INEOS then modified but that's 'proprietary' to manage the B57/B58. I think this is part of the delay in getting a solution out to DIYers who take care of their own vehicles. You can get your Grenadier serviced elsewhere, but that non-INEOS servicer can't change / reset specific things in the ECU via standard BMW tools. Maybe European custom is that car owners don't change their own oil, and so wouldn't need to reset the oil change value? But in a BMW vehicle you can do that reset, without tools, without scanners, just using a sequence of steps with the car. Right to Repair laws are starting to be passed in some US states, I would hope eventually a federal law would be passed, not with this 'administration' probably. Doesn't help any of us right now though. Hoping someone reverse engineer's the entire setup and we can manage our own vehicle states directly, do oil resets directly. If I'd been involved in that decision making early on I'd have not gone with Bosch or whomever, I'd have certainly pushed for a more open system base to build upon. The Grenadier was positioned as a DIY serviceable vehicle.
Well that is were it is strange, the ECM is still BMW system fully and Bosch bench locked, however the communication layer that you can say stitches the comms together and user inputs is Ineos. Sadly right now a standalone might be the only way around it.
Actually the top layer is provided by Neusoft, as such configured to Ineos' requirements.
Neusoft also produce this top layer for Geely, including the Polestar range amongst others less familar outside of China.
I keep meaning to try the Polestar service reset which is a complicated combination including brake pedal presses.
Yeah that could be true as well, who ever built it has encryption that requires a physical Bosh MTS 6531 connection and a two factor auth. I have tried to clone my for a better term headunit but no win there. Either way Ineos is actively blocking the user from connecting.
No doubt it can read and clear codes.
Serious doubt on the service reset. The IG is not a BMW like those other brands. Nice if by some chance it does work.
I don't think it will work. I say this because I had a large chain mechanics shop do the 1 year service, I had 1600 miles. I didn't have an oil change light, however they attempted to get it to the computer and they couldn't get to the reset. They called me and asked do you want the oil change to be done or go to the dealer. I said do it when the light comes on I'll take it to the dealer. They told me their equipment is excellent but they are locked out no less. When the light comes on I will use my Ancel and give it a try.
I bought this code reader to reset oil service reminder after I changed the oil. It does not work.
What is the warning or alarm that pops up if you don’t get the service interval reset? It is $200 charge to reset that interval here.
You get a loud bong on start up and warnings flashing up. I think there are three counters at play, elapsed time, running hours and miles, so it can get a bit busy!
This is one of the very few things that galls me about the Grenadier: it is a classic example of "bait and switch" perpetrated by whomever contrary to expectations generated before actual sales were made. The lack of an ability to either turn off or manually reset the service indicator, then charge an exorbitant fee (presumably because the OP did their own service) to do same, wreaks of petty mindedness. Lynne C's promises not withstanding. It should have been sorted before we took delivery.. Accounting types and the engineers beholden to their purse strings might think it's smart and clever... To the customer, it's a total betrayal of the implied independence to service and maintain that was promised. .🤬
