OBD2 Dashcam
Shaky
Forum Donor
6:12 PM
Hi guys, been a while since I posted on here.
I am after some advice around using a power adaptor that uses the OBD2 port for a dashcam, is anyone using the system and have they had any problems or is it pretty much plain sailing. Have read they can throw up some fault codes but a lot of that seems to be old posts around the internet. I believe the cable is fused and there is also a lower power sensor so it won’t just flatten the battery while parked.
It might be relevant to say I am looking at the fairly unobtrusive Nextbase Piqo 2k camera and the OBD cable that is associated with it.
I know all about the wolf box and hard wiring etc etc, but I don’t fancy taking half the vehicle apart and I want something that can be removed fairly quickly and easily. I have fitted one in my 2016 Amarok and that was a 10 minute installation with VW having the foresight to put a 24v socket on the top of the dash in the middle. I don’t have that luxury in the Gren.
I use an Escort M2 Dashcam that pairs with my Escort Redline 360 dash cam. It’s powered with their OBD2 cable and I’m very happy with it.
I tried a generic cable years ago with an X5 I had and wasn’t happy with it, the Escort stuff though all plays nicely together and it’s reliable.
“I believe the cable is fused and there is also a lower power sensor so it won’t just flatten the battery while parked.”
Does that mean that the camera is alway ON?
I believe so or on standby anyway
Parking mode will start recording if the dashcam feels the car being knocked
OBD2 power adapters are generally fine and much easier than hardwiring. I've used one in my car for over a year with no issues.
The key is to get a good quality one that has a low-voltage cut-off to protect your battery. It should work without throwing codes. Just plug it in and you're done. Easy to remove when needed.
Go for it, it's the simplest solution.
Rob, thanks for the reply mate. I am going to go for it.
The Nextbase OBD cable is built for and only works with the Piqo units and as you say it does have the low voltage cut off built it.
As and when I get it, I will report back if I encounter any problems on the Grenny. I am a new convert to Dashcam’s and feel a lot safer (against lies and B.S) having one whilst I am driving.
This seems an easy way to keep the wiring to a minimum and all centred around the dash area. 👍
