Model Year 2026 (MY26) – Confirmed & Speculated Changes
Looks like 2026 removed the "winch prep" as a standard part of the Trialmaster high load auxiliary switch panel.
I checked the maintenance manual, and I noticed a potential difference. Not sure if it really is the difference between '25 and '26 rearview mirrors.
Can we figure out who the manufacturer is of the new '26 mirror? It would be great if we could get a backdown of that mirror. I am thinking if we take one apart and access the camera behind the mirror glass and mount that outside the mirror so we could use a wolfbox or similar aftermarket mirror.
I wish I had more time with it in person.... I plan to go back maybe next week, might be able to take a couple pics. My hope was the mirror was just an LED that lights up but looking around at it, it must be the camera system as well for looking at the driver.
Is the HVAC issue simply related to low refrigerant (on the cooling side) and low coolant or need to bleed the system on the heating side? I've read several owners report doing either or those things have fixed their issues but also read about hardware and whole systems being replaced and redesigned.
Is it something that can be remedied in the pre26 cars?
My service advisor said they will actually replace a faulty valve per IA. Mine blew hot a handful of times when I was asking for full cold.
Ok, here's my thought on the wolfbox...
the rear view mirror, is where it is, because its the best angle to reflect most of what you want, but we still cant see shit.
In the 50's, it wasn't uncommon to see a rear view mirror on the dash. due to glass technology and thin frames on cars like corvettes. so, there is another location
Now, I like to see WTF the morons are doing in the back (see dog thread), and fix my hair (see self effacing comments to the contrary), and have considered mounting the wolfbox on the dash above/behind the existing screen. My plan since I got the truck has been to utilize the a pillar grab handle mount holes to mount a cross dash pipe for various electronics (ipad mini, ham control, obd speedometer), and the wolfbox.
It's camera view. It doesnt really look or act like a real rear view mirror. i cant see different angles by adjusting my head. There's no reason it has to be there, in place of the mirror.
My issue is, I can't keep my truck out of the dealer shop long enough to commit to the offroad conversion, and other obvious setbacks involving the front prop. There's no point in taking the time to fabricate that for a mere DD.
But anyway, just put it on a ram mount ball that I think someone has made to go over the back of the screen. I think someone made something there for phones or doo dads.
I totally hear you out, being creative and finding new location makes sense for some. However I don't need to see in the back of the station wagon looking for pups or kids. I really like the location of the screen being where I now naturally look to see out back. Honestly I have vehicles that the rear wing block it and I don't really care, but that is a two door car compared to this bus. lol The wolfbox for me the winning part is the view you get and I've tested this by having a friend walk by you really really limit the blind spot with the wolfbox. Maybe if I had different side mirrors that might of helped solve but then again I also use the front camera ALOT while off roading. I think its a give and take with the situation of the consumer 100%
It may also be a faulty valve in some vehicles but the main changes to HVAC in MY26 are the addition of a second stepper motor in the baffle system rather than using one motor with mechanical linkage, and better balancing and shrouding of fan to reduce noise and vibration. The single stepper with mechanical linkage would sometimes struggle to adjust the baffles.
Is this able to be installed in the ‘25s? I imagine this will be the question.
Hi all,
Surprised that there is such little talk about the next model year, while it’s right around the corner.
Starting this thread to collect everything known about the MY26 Grenadier — confirmed updates, observed differences, or dealer info.
I can make the start of what I’ve been told by dealers so far.
🛞 Steering & Drive
  • Updated, progressive steering: lighter around centre, slightly smaller turning circle.
  • Lane-Departure Assist: brake-based correction through ESP, not active steering.
  • No confirmed CV-joint/driveshaft redesign yet — did anybody hear something?
💡 Exterior / Lighting
  • Headlights now with twin light-pipe signature (mostly cosmetic).
🖥️ Electronics
  • Heard about a new split of the infotainment display with no further details being provided.
Any additional information / news that you have come across, please share.
Just bought one a week ago. Salesman said there was a HVAC “improvement. I read into it as a “reprogramming” of the “Auto” function performance.
Here's what my dealer did to fix my 2024's blowing hot when AC cold and some interior water droplets issue. Perhaps there are some folks who don't want the 2026 for whatever reason(s). We'll see if it actually got resolved over time.
Rusnak Pasadena has been good to me to date (aside from IA rejecting squealing steering pump complaints outright).
View attachment 7921280View attachment 7921281
Payliad improved after all that gas removed!
I was wondering what the 540kg referred to, is it missing a decimal point or is that the weight of the gas on Jupiter? Also can someone in the car service business clarify the "start of straight time" / "end of straight time" terminology, is it where Ineos pays a fixed amount for part of the job and a timed rate for the rest?
Can be either or, but most commonly seems to be air in the coolant loop when vehicle is delivered. I believe the dealers should be bleeding the system as part of their pre-delivery procedures and some may not be doing this. It is a relatively easy routine for an owner to run and may help resolve many of the HVAC issues, I found doing it resolved my problem (poor heating performance in our mild winters) and my HVAC now works fine winter or summer.
The vast majority of brands use Gentex mirrors; I would appreciate it if someone could confirm this. On the other hand, I have noticed that most people install Wolfbox units, but I have not seen anyone install the GENFDM3LN model, which in my opinion offers a much more OEM-like appearance without losing the original mirror functionality.
That is the company that I was thinking. However, I couldn't find anything remotely close to what I think I was looking for. I am probably way off base on that though.
Discussion including Gentex here.
