Low Current Air Compressor Power from Roof Outlet
Kenza
10:46 PM
United States
VIAIR makes a compressor with 23A max current draw. Its current draw from 20-50psi is 15-19A respectively. Model# 450P-A EF here https://viaircorp.com/products/450p-ef-automatic-portable-compressor. Technically, this compressor can be powered from the EXT 2 roof outlet with its 25A ratings. May be change the fuse on the compressor wiring to a 20A fuse. do you see any issues with this? it will be slower than a more powerful compressor with a higher draw, but there are advantages if this is safe.
I’d be interested to know how long it would take to inflate 285/70 from 20 pounds to full? i’m not going to be putting anything larger than that on mine anytime soon.
I would prefer to connect under the bonnet than temporarily connect to the EXT roof outlet.
Post up real world compressor info when you get it.
The last thing I wanna do is open the bonnet. With my luck that’ll be the only time people stop by to ask if I need help. And I don’t like talking to strangers. Even the under seat and rear cargo area ones I’m not as hip on because of having to have a door open in potentially inclement weather. Especially if they can deal with your standard size tires pretty well being able to plug-in on the exterior seems like a pretty interesting option.
The ARB dual compressor draws 28 amps, with startup of up to 57 amps. Be ready with extra fuses in case your inrush exceeds the EXT amp rating.
This VIAIR draws max 23A. It should work just fine with EXT2, 25A rating. It will take take more time than ARB compressor but with this, you could set inside flip EXT2 on and watch the pressure as it goes up then flip EXT2 off, or at least that is the plan, planning to do two tires at the same time. we will see how it works when I get the compressor.
Any feedback? I like the higher capacity options, but they are pricey. If I had 37s, and friends with 37s, I might be more discriminating, but realism is starting to creep in….
My tire is 265x70x17, it took 2 minutes and 30 seconds to inflate one tire from 20 PSI to 41 PSI with this compressor. I set it up, went into the Grenadier, engine on, switched on PWR, then EXT2 and watched the pressure go up on the Grenadier's screen, once at 41 PSI, switched EXT2 off, then PWR off. Best switching action in a long time!!, this works very well for me. I replaced the inline fuse that came with the compressor to 25A. I am planning to inflate the front tires together, then the back tires.
