Let’s talk Update 24.1
Had my software updated last week...first one did not work on the Over SPeed Warning...but a new release came 2-3 days later or that is when dealer got it relevant to my appointment...so took it back 3 days later and new update installed. I no longer have to select SPEED WARNING OFF every time....works as promised. Still have to do AUTO STOP but that is small beans. Only sw updates I think I want now are:
- stability for Android Auto so it does not fail connections sometimes
- accurize altimeter...has to be software glitch taking it from GPS and converting it to display on altimeter and offroad mode views
- ability to reset service light if changing fluids myself
What state and city do you reside in? Our dealership Sierra in Cali still doesn't have the software update.
I am in Charleston SC. Hendrick Ineos. I have not had to go to Favorites and select OFF for Speed Warning in over a week. I still have to let system boot up and connect to Android Auto...and then push AUTO START/STOP button .....but so much better than having to also go into menu for Speed Warning. Small victories. ;)
Just had my 24.1 updated this week. Happy with the lack of over speed warning, or having to disable it.
The thing I noticed, but I’m not quite sure about? Is that the shift from drive to reverse takes two pushes now, or did it always? If I’m in drive and I try to put it in to reverse, it gets hung up in neutral and I have to then push again on the stick to get it to go into reverse. I seem to remember in the past that going from drive it would hesitate or hit like a bump in neutral and then go into reverse. Kind of a pain in the ass, but like I said, I’m not sure if he didn’t do it before and I’m just crazy?
At first, I thought it was because I wasn’t pressing the brake pedal hard enough. But that’s not it. It’s also not like I can push harder and it will go in reverse.
Anybody else notice this? I think it does it also the other way when you’re in reverse, it hangs up in neutral and then you have to tap it again to go to drive, but I’m not sure.
I back into my driveway every time and didn't notice a change in D to R... From memory it's just one slow/long push
This isn't right at all....... I'd probably get back into the dealership on that one.
Nothing different on mine.
Fuel level sensor was patched and working a while back. 24.1 patch applied. Now, fuel level sensor error is back.
So I can go from reverse to drive in one motion with my foot on the brake.. I’ll have to see if I can do it without my foot on the brake. But if I try to go from drive to reverse, I have to hit the side button to get into reverse.
I guess that makes sense because you don’t wanna be driving along and also throw it in the reverse? Maybe it’s always done that. I’ve just messed with this while I’m sitting still with my foot on the break. When I get out of the driveway, I’ll test it on a slow roll. Just thinking about situations where you wanna gain momentum going backwards and forwards I could see this causing an issue?
I also thought there were less lights coming on when I turn the car on. I still follow Thom‘s advice from Red Noland on putting the key in doing the first turn to let all the computers come up and sync and for all the warning lights to go out that will go out, and then starting. I think the difference was that the dealer had turned off my automatic headlights so I wasn’t getting those two green lights coming on.
I thought you sold yours.
I did, I guess I should have said "I used to back in"... Perhaps there are unspoken things at play here :P :P
My apologies, I wrote this comment right after I was disoriented from hearing that wretched noise. I also have an upgraded sound system, so you can imagine how bad it is.
hahahahaha...just messing with you. It goes off and have no idea what it is saying....until look at everything. LOL My gong goes off for fuel even before I start car sometimes.... but only does it once while driving. Hopefully, I will be replacing my speakers this year...and maybe have a sub installed similar to my FJ Cruiser I had years ago...filling that area on right rear side in cargo area above fender hump.
Between Chicago and Milwaukee on I 94 there’s a sign for the “bong recreation area“. No crap. It’s actually for drumroll, Dick Bong, really Richard Bong the World War II Ace. Can’t imagine how often that sign has been stolen.
Was the loud low fuel bong supposed to be disabled after update?
Mine is still there after 24.1 update.
At 71 miles left…it gonged every minute or so even after I cancelled/acknowledged. Really annoying as my commute is short, 71 miles is another week for me. I stopped to fill up just to shut it up.
Gauge was between 1/4 and 1/2 too. So still an issue.
They may have used the incorrect software fix. There are two....one for very early models and one for those after. They did mine with the incorrect one initially and then the following week installed the CORRECT one and it worked perfectly. I think they told me there was an UPDATE to the software fix that covered mine...a early 2024 model.
They may have used the incorrect software fix. There are two....one for very early models and one for those after. They did mine with the incorrect one initially and then the following week installed the CORRECT one and it worked perfectly. I think they told me there was an UPDATE to the software fix that covered mine...an early 2024 model.
No, I’m a 24.1…and other things are fixed just fine. It’s just that gong. I also think that the gas level sloshing around a little bit right at the low level alarm might make it come and go.
I have an early model and the fuel gong was not fixed either. I wonder if it was fixed in the update for the later models.
