Leaking - Multiple Areas
Look forward to hearing what Triad has to say!
Thanks for your input here. Was the leak resolved, and what was the culprit? My Grenadier just showed droplets on the dash under the camera for the first time after 9 months. Bummed for sure...
I had the same issue with the safari windows. The dealership couldn’t fix it the first time, but after replacing the rubber seal, the problem was solved.
Your drips were on the dash like mine? My drips seem like they are coming down from the windshield camera/rearview mirror which seems like good distance from the safari windows.
Yes, the same spot. Water travels to the lowest point of the roof.
The same thing happened to me a few months after having the car, when it rained hard the roof of the car got wet but only the right part of the roof, around the safari window. At first I didn't know what the problem was. I took it to the official workshop and they put silicone around the rubbers of the safari windows but one day when it rained hard water came back through the ceiling. Tired of not having the problem solved in the workshop, I decided with the help of a friend to move the roof rack backwards, remove the safari windows and see what the problem was. The drain of the right safari window was blocked and did not evacuate any water. We unclogged it by putting pressurized air on it and everything worked properly even in heavy rain.
Just a gentle reminder, I had overland gear guy make me a custom magnetic cover that spans over the outside of the safari windows. You put it on when you are parked and then take it off before driving. It rolls up easy and is simple solution to keep the safari window area clean.
@OverlandGearGuy Rob, are you still making these magnetic covers for the outside of the safari windows?
Would order a set in a heartbeat! Had my safari window seals replaced under warranty and during a downpour/deluge the passenger side still leaks a little bit. But with a cover it’s no problem.
If leaking on the flat, get onto the dealer and message INEOS who will also get onto your dealer.
Mine leaks facing uphill at about 11⁰, the dealer is trying to get help from INEOS 🤣🤣
Already had it into the dealer to have the seals replaced. Took two trips as the first time the replacement seals were damaged upon shipment from Belgium.
I’m not going back to the dealership for this. It’s too much of a PITA and I’m tired of having the truck down for work, living in Southern, California gives a bit of leeway there. I’ll replace the seals myself the next time and likely will add a bit of sikaflex this go.
But I use an environmental spill control drain cover made from very soft Polyurethane and that works a trick. Just a bit of a thing to carry and put on.
So looking to make something that’s easier to carry and works well. I.e. neoprene material or the like. Just need an extra barrier for the deluge. Otherwise the seals and drain can handle it.
Mine had seals replaced and used the goo of some sort a number of times. Also had it so that it clamps tighter. Last time they added an extra part where it drains. Nowhere near as bad as it was. Water leaks in between the glass and the seal of the rear part by the handle or the corner? Only when facing uphill.
